Old 04-28-2012, 06:42 PM   #1
1976 Argosy 24
Lebanon , Pennsylvania
Extra layer of aluminum
We are newbees & just started on the floor of our '76 Argosy. After ripping out the front floor section we discovered an extra layer of aluminum between the wood flooring & the frame, just down the center. Is this common?
heckbo76 is offline   Reply With Quote
Old 04-28-2012, 06:46 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
In the front of the trailer you might have a sheet of aluminum if you had the spare tire mounted there. This would keep the floor from being exposed to the elements since there would be no pan in that area.
Richard
Old 04-28-2012, 06:57 PM   #3
1976 Argosy 24
Thanks for your quick reply. The belly pan is still attatched & there is no spare under there. We weren't sure why the extra piece was in there and if we should keep it in or not.
Old 04-28-2012, 07:33 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings heckbo76!
Welcome to the Forums and the world of Vintage Argosy ownership!
I have not heard of this extra piece of aluminum below the plywood subfloor but above the frame, but Argosy was something of a test bed for ideas that were under consideration for application in Airstreams . . . so this may be an example of something that was tried as an experiment . . . . or it may be something that was added by a prior owner or during a previous repair.
Good luck with your Argosy!
Kevin
P.S.: Argosy Minuets served as a test bed for composite aluminum floors just a year after your coach's production.
Kevin D. Allen
AIR #827
Old 04-29-2012, 02:32 AM   #5
1976 Argosy 24
I can tell we are going to rely ALOT on this forum. Thanks for the info.
Old 04-29-2012, 07:18 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Every Airstream and Argosy from 1969 and newer should have that piece of aluminum between the plywood and A frame. That was so if a customer decided they wanted a spare tire holder installed, the dealer could simply cut out that part of the belly pan and not have to disassemble the front of the trailer to install that aluminum sheet.
I havevseen that sheet in trailers as early as 1965 models.
Old 04-29-2012, 10:45 AM   #7
1976 Argosy 24
good to know, thank you. Today we found alot of ant damage & alot of live ants. Good thing we had a can of spray handy. We could see the trails they made through the insulation & the plywood.
Old 04-29-2012, 03:44 PM   #8
mapleton , Utah
ANTS! I THOUGHT MICE WERE BAD!
Seriously, toss in a couple of bug bombs and shut it up tight.
Next question is how much damage did they do and how do you repair it?
rumrunner is offline   Reply With Quote
Old 04-29-2012, 04:33 PM   #9
1976 Argosy 24
These ants are very nasty looking. They must have been in there when I brought the TT home from up state PA. These critters were between 1/4 to 1/2 long with big pintures . They tunneled through the fiberglass just like you would see in a kids ant farm. they also went up through the front walls . They put the insulation in the belly pan. they also made paths through the plywood the same way.They had themselves sandwiched between the plywood and aluminum panel an the floor. I will be dropping the belly pan next weekend so i can continue on the front floor replacement. Glad I had bug spray on hand. Do not know what else I may find as I continue remodel.
Old 04-29-2012, 07:59 PM   #10
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Sounds like a bad movie.. Good luck and with hope a few months from now it will be a good story..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 04-29-2012, 08:08 PM   #11
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
There are several 'Rocket Scientists' on this site.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
