Old 08-07-2007, 10:51 AM   #1
Cos
1973 21' Globetrotter
Middletown , Rhode Island
Extra factory holes in Plywood Floor
I have a 73 Globetrotter that has several extra holes (circular and oval) in the plywood floor, one in a closet near the rear bath shower, others near the furnace/fresh water tank. Do these holes serve a purpose (maybe allow heat to make it in to the bellypan in these areas?) or can they be covered (maybe the factory cut the plywood for use in several models)?
Cos is offline   Reply With Quote
Old 08-07-2007, 11:02 AM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Cos,
In my former 64 GT, I had several just as you described on the street side front of the unit. From old floor plans, it would appear that some floor plans had a furance in this area..?? My 64GT didn't have the furance installed and, the outside vent opening were riveted over/closed. My thinking is: At the factory, worker bee must have had a "common" jig to go by and, just cut away??
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 08-07-2007, 11:12 AM   #3
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Cos, in my '73 Overlander, there's at least one cutout under the bed that's not used. IIRC, it was for some electrical connection/device that was required for Canadian models. The factory probably just used a standard pattern for all Overlanders of the day.
www.nesa.org
Air No. 6427
Old 08-07-2007, 11:51 AM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
They are critter access points.
Vaughan
Old 08-07-2007, 02:41 PM   #5
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
COS,
Has enyone replaced or updated your plumbing? When we pulled all the copper out of the 60 TW there were no less than three drain outlets in the system for winterizing.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 11:21 AM
Bathroom Floor Repair John Sims Repairing/Replacing Floor &/or Frame 4 01-09-2003 12:13 AM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
Partial Floor change winner Floor Finishes 12 07-22-2002 06:08 AM
Survival supplies On the Road FrankR On The Road... 7 04-19-2002 01:54 PM
