Old 03-13-2015, 08:10 AM   #1
1974 27' Overlander
North Granby , Connecticut
Elevator Bolts
Good Morning
I have a question on installing elevator bolts ? I am in the process of gathering my material for the spring when I plan on removing the shell on my AS 1974 Overlander. The bolts that were installed at airstream seam to be made of carbon steel and are 1/4" X 2 1/2" long. Has any one out there replaced them with 5/16" or 3/8" stainless steel elevator bolts? Or did you use the carbon steel bolts. I would appreciate some feed back on this as i have located a source for the stainless steel bolts.
Big G
Big G is offline   Reply With Quote
Old 03-13-2015, 08:35 AM   #2
1977 23' Safari
Carberry , Manitoba
I just finished redoing the rear floor in my safari and just used steel bolts. I didn't bother with stainless as I thought if there was enough moisture to rust them out, my wood floor would be long gone even though I soaked my wood floor with polyurethane finish prior to installing.
cp1977 is offline   Reply With Quote
Old 03-13-2015, 09:04 AM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Not on an Airstream, but on our 42' pontoon houseboat. I used steel elevator bolts. If a part of the deck had to be replaced, I would remove the bad wood, giving me access to both ends of the bolt which would get replaced with new anyway.
I wouldn't bother getting the high priced spread.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 03-13-2015, 09:33 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
new technology
Make the switch to new technology. If these flooring screws had been available to early Airstream builders they would have been used. Way better, made for flooring, self tapping, in expensive and fast/easy to install.https://www.fastenal.com/web/product...%20Screws%22|~
Old 03-13-2015, 09:50 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
I used steel for my last project.
The frame will corrode before the bolts will, because it's thinner. Stainless steel bolts are weaker.
Old 03-13-2015, 06:03 PM   #6
1974 27' Overlander
Thank you for your inputs for the elevator bolts. I went out end tried a 5/16 bolt to see if it would fit I to the bolt holes and found out that the 5/16th bolt was to large for the hole. Still has any one replaced the elevator bolts with stainless steel instead of the carbon steel bolts?
Big G
Old 03-13-2015, 06:47 PM   #7
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
I replaced the floor in my motorhome with 1/4"-20 stainless steel machine screws from Albany Fastener on E-bay. They were very reasonably priced and they shipped really quick. The screws were flat head with an Allen drive You can get a lot of torque on a Allen head. I used a tap to cut the threads which is an extra step compared to using cutter screws but, it worked really well.
Gregsch is offline   Reply With Quote
Old 03-13-2015, 07:23 PM   #8
1998 30' Excella 1000
Livingston , Texas
Jammer makes an important point. Look up torque and tensil strength tables for stainless vs steel. I replaced my entry door hinge bolts with 1/4"-20 stainless, and was able to snap off two of them without much effort using a short handled rachet.
Siegmann is offline   Reply With Quote
Old 03-13-2015, 10:11 PM   #9
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I have used stainless elevator bolts.
http://www.airforums.com/forums/f36/...tml#post979472
If they are to be covered, I'd just go with cad plated e bolts.
Lance
Top is offline   Reply With Quote
Old 03-20-2015, 01:45 PM   #10
1974 27' Overlander
I wood like to thank every one for there input on the elevator bolts. I have order the stainless steel ones and s.s. fender washer, lock washer and nuts. Am in the process of building a gantry system to place over the shell to remove it to get at the floor.
Old 03-20-2015, 10:04 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thank you! I Need some for next time I remove my "gaucho"!
Old 04-27-2015, 01:38 PM   #12
1968 26' Overlander
Wolfforth , Texas
Smile Fastenal screws?
Which fastenal screws are you referring to? When I hit the link it just takes me to the main page?
lakoria is offline   Reply With Quote
Old 05-06-2015, 12:32 AM   #13
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
I just discovered after dropping the rear belly skin that the guys that replaced the last 4' of the floor used screws to secure the C channel to the the floor. But they didn't go through to the rear frame channel
Now that the inner panels are in and a bunch of systems are installed on them, what to do to install elevator bolts ?
Light bulb ! 1/4" x 3" toggle bolts installed from the bottom ! Ya, I know, I know it seems odd but what am I to do tear out all the work to install elevator bolts, Not !
They have a rating of 90# in dry wall and they pulled the floor tight so I'm happy.
The big pain was using a 11/16" hole saw to make the holes and digging out the cores. On the plus side I now have a bunch of 1/4" washers made from the Airstream
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Stop using Elevator bolts? Forrest Repairing/Replacing Floor &/or Frame 3 04-13-2008 10:17 PM
Elevator bolts????????????? 58BUBBLE Repairing/Replacing Floor &/or Frame 35 08-24-2007 10:50 AM
Where are your elevator bolts? byamcaravanner Repairing/Replacing Floor &/or Frame 9 07-17-2007 03:54 PM
elevator bolts tracker Repairing/Replacing Floor &/or Frame 2 12-13-2005 02:11 PM
