Old 02-26-2013, 10:34 AM   #1
1966 22' Safari
Matagorda , Texas
Elevator bolts
I've gotta ask.are these bolts for leveling the floor where there is a distance between braces?,
Greg65 is offline   Reply With Quote
Old 02-26-2013, 10:46 AM   #2
They're used to hold the plywood subfloor down to the frame and outriggers. They're useful for that because of their wide, flat head, which distributes the point load a little bit and acts as its own washer.
Not sure why they're called elevator bolts.
Old 02-26-2013, 11:05 AM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
What utee94 said.
They are called elevator bolts because of their use in grain elevators. They are usually found next to the plow bolts at Tractor supply and Fastenal.
Elevator Bolts: Fastener Mart
Lance
Top is offline   Reply With Quote
Old 02-26-2013, 11:29 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Greg,
Do you have a gap between the plywood floor and the frame? Got a picture?
Chris
Old 02-27-2013, 05:11 AM   #5
1966 22' Safari
Matagorda , Texas
Chris
Yeah there were some frame braces in the rear bathroom that had rusted.i took angle iron and bolted it to the non rusted parts creating a small gap.i figured I could take the bolts and use them as a spacer as well as using them to bolt the floor to the frame.
Thanks.
Gregg
Old 02-27-2013, 06:26 AM   #6
Minno's Avatar
1972 31' Sovereign
How about using fender washers to fill in the gap?
Old 03-04-2013, 09:28 PM   #7
1973 Argosy 24
Houston , Texas
Chances are really good that you have rusted out bolts too. I was shocked at the residual dimension (what's left) when I cut the bolts out. I'm doing a shell off restoration on a Argosy.
Hotpuppy is offline   Reply With Quote
