Old 12-13-2010, 04:43 PM   #15
1968 20' Globetrotter
Kelowna , British Columbia
Originally Posted by 68 TWind View Post
If you get the rotten wood out of the way, a cut-off wheel on a 4 in grinder makes quick work of the rusty bolts. In tight spots I used a dremel with a cut off wheel. Luckly, in most cases, i just grabbed the end with a big pair of Vise-grips and a couple of bends back and forth both them off ( most of my bolts were very rusty )
This worked well for me too. A few hard to get at spots I used my Fein Multimaster to plunge cut through the bolt. I used flat washers and nylocks and held the bolts with vice grips on the few that wanted to spin.
Canlib is offline   Reply With Quote
Old 02-05-2011, 07:19 PM   #16
StPierre's Avatar
1965 22' Safari
Rescue , California
Steve,
Did you start your floor replacement from the fender wells then work forward from the rear? Or did you start at the front and work back?
Thanks for the help
The St Pierre's
StPierre is offline   Reply With Quote
Old 02-06-2011, 10:51 AM   #17
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
center
Originally Posted by StPierre View Post
Steve,
Thanks for the help
Started at the rear as my bath floor was only 1/2 there.The center piece would be a good place to start as it is not under the channel.
bwaysteve is offline   Reply With Quote
floor bolt question toaster68 Repairing/Replacing Floor &/or Frame 7 02-03-2010 11:52 AM
Elevator Bolts Mrhany Repairing/Replacing Floor &/or Frame 6 12-29-2009 06:07 PM
Another Door Dead Bolt Question rc707 Doors & Locks 11 05-03-2009 06:41 AM
lug nut/bolt question.... Kistler Wheels, Hubs & Bearings 13 01-25-2006 02:15 PM
no answer on the lug bolt question donhardman Wheels, Hubs & Bearings 3 05-04-2005 11:50 AM
