Old 02-03-2011, 04:08 PM   #1
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
elevator bolt insulation
Hi
Just getting to the point in my rear floor redo that I will be installing new elevator bolts. I was thinking of using some plastic tubing cut to length for each bolt. Tubing would slide over bolt and insulate the steel from the aluminum. Holes in the c Chanel may have to be enlarged slightly. Anyone tried this method of preventing the corrosion problem? Also thinking of placing thin rubber under the steel anchor plates for the same reason.
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 02-03-2011, 05:03 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We did not have any corrosion around our old elevator bolts when we redid our floor. Not sure that it's a necessary thing to worry about. I would think road vibration would cause the C channel edges to cut the plastic tubing anyway, and then you would have enlarged holes around your elevator bolts and a looser than desired connection between your C channel, floor, and frame.
Chris
Old 02-03-2011, 05:24 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
It takes moisture for the galvanic corrosion to happen. If everything is sealed up and kept dry, you should not have any problems.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 02-03-2011, 06:03 PM   #4
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
Would painting the steel bolts have any extra assurance?
Rae
via~ AIR Forums App.
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline   Reply With Quote
Old 02-03-2011, 09:23 PM   #5
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
The elevator wide-head bolts were to bind the plywood - I didn't use them, my '73 used self-drilling & tapping screws on the plywood spaced every eight inches - but anywhere Aluminum was involved I used Stainless Steel bolts and extra-wide 'fender' washers. If you want to isolate anything from the aluminum, cutting plugs from the walls of two-liter pop bottles as washers would work nicely.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 02-04-2011, 04:45 AM   #6
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Originally Posted by tvanwave View Post
Hi
Hi tvanwave;
If you are concerned about use Stainless Steel elevator bolts. The dissimilarity in metals between steel frame and SS bolts is negligible. Use 0.065 X 2" 3M liners tape to seal the ply from steel frame. Tape will seal any and all moisture from entering the contact area between frame and ply. As someone already mentioned it takes moisture for corrosion to take place. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
1991 limited, 34'
My insulation progress....The triple layer combo ddstech General Interior Topics 46 08-25-2011 03:00 PM
22' Airstream lovejoyart General Interior Topics 6 01-12-2011 04:20 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 06:42 PM
