Old 10-20-2012, 01:26 PM   #1
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
Electric stabilizer for Airstream Classics
Has anyone replaced their manual crank stabilizers on the classic with ab electronic system? Any recommendations or experiences with this would be appreciated. I'm trying to avoid having to get down on my knees to crank up the stabilizers.
wolverine is offline   Reply With Quote
Old 10-20-2012, 02:46 PM   #2
dznf0g's Avatar
Oswego , Illinois
Try and electric 18volt cordless driver/drill with a sockt adapter and a 3/4" socket. Fast, easy, and no kneeling.
-Rich-
Old 10-20-2012, 06:17 PM   #3
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by dznf0g View Post
Try and electric 18volt cordless driver/drill with a socket adapter and a 3/4" socket. Fast, easy, and no kneeling.
This works great just don't try an impact wrench (noisy and jars the stabilizers and trailer).
Old 10-20-2012, 08:41 PM   #4
dznf0g's Avatar
Oswego , Illinois
A lot cheaper too....and you have the drill for those other on the road "projects".
-Rich-
Old 10-20-2012, 10:03 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
With the powered stabilizers you are more likely to have a stuck stabilizer if a motor, power supply, or gear failed. The drill is easy to use and cheap, you probably already have one.
doug k
Old 10-21-2012, 11:17 AM   #6
SStar's Avatar
2004 28' Classic
Midland , Texas
electric stabilizer
Agreed, an 18 volt 3/8 drive drill works great. I use a 3/4" socket and a long 3/8" drive extension with the end cut off so it will chuck in the drill. I welded a bar on the extension at right angle to manually assist the drill in case the stabilizer binds. I also screwed pads to the bottom of the metal plate on the stabilizer to provide a larger surface. They just ride along when the stabilizers are up.
SStar is offline   Reply With Quote
Old 10-21-2012, 11:25 AM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Just keep a good grip on the drill when you get the stabilizers down all the way. Otherwise the drill handle pops up at you and you can get a nasty bruise on your chin..... .
Kay
Old 10-21-2012, 12:40 PM   #8
1977 Argosy 24
Milltown , Wisconsin
Kay
I wonder how you know that?
ventport is offline   Reply With Quote
Old 10-21-2012, 02:31 PM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
A cordless impact driver works even better than a drill. Because there is no counter rotating force when it hits bottom. Down side of the impact driver is noise, but it is fast and effortless and I prefer it to the drill.
Old 10-21-2012, 03:01 PM   #10
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Just select the right torque setting and you won't get jangled by the drill. Chose a low setting and work up until you get the the one that works best. Then just set it and forget it.
Note: I didn't mean to say "jangled" by the drill. My auto spell did that. But I can live with it.
2012 Dodge Durango Hemi/AWD
Old 10-22-2012, 08:51 AM   #11
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
cool concept
Had to confess that the concept is real cool.
We found this on our Avion project, It seems like is not in working condition but we didn't get to work on any electrical part yet.
Now we found 2 independent controllers for each side, all controllers are in the front so the 4 landing gears have an independent switch, again, cool concept.
Hope the pictures help.
ID:	171051   Click image for larger version
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 10-22-2012, 09:17 AM   #12
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
My wife bought me the 18 volt drill with the socket. Now I get absolutely no exercise. Life is good. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
No LP - All Electric, is it realistic? J.air.doe Electrical - Systems, Generators, Batteries & Solar 40 02-07-2015 05:40 AM
'76 Argosy Steering Stabilizer - help MrJ Mechanics Corner - Engines, Transmission & More... 9 05-08-2012 09:57 AM
Am I Stupid? Water heater gas and ELECTRIC THEPILL Off Topic Forum 25 10-21-2011 05:08 PM
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 7 02-01-2011 03:07 PM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
