Old 12-02-2006, 09:56 PM   #1
Profile:  1998 30' Excella 1000
Bayside , California
Question dragging the rear end of my 30' excella in the skid wheels
I had just purchased a beautiful 1998 30' excella and and pulled into the first gas station I saw when I heard a loud scraping noise as I pulled into the driveway. I found pieces of the small drag wheel littering the driveway and the corner of my new airstream appeared to be accordianed slightly. Since I'm towing this beauty to Cabo San Lucas in Baja this month you can imagine my concern with the low profile. I took the trailer to the local RV service center in Eureka CA and the technician measured the clearance of the frame to the ground front and back and it was equal at about 8 inches. I asked him if it wouldn't be better just to leave it off since the small wheel occupies about half of the available clearance space and he looked at me like I was crazy talking. Was I ? Is this a problem with other airstream owners? What else can I do besides just be dam careful on driveway approaches and anyplace else that the road is uneven. Bigger tires maybe? This could be a serious challenge especially in Baja. Any ideas would be greatly appreciated. thank- you, Greg Mellon
gtmellon is offline   Reply With Quote
Old 12-02-2006, 10:14 PM   #2
2airishuman's Avatar
Profile:
hi greg and welcome to the forums...
baja...man you will have to give us reports....lots....and pictures.
i want to spend part of next winter there.
take the drag wheels off...they only reduces clearance.
someone added them as a/s don't come with them, or need them
the frame has a small spot that is low enough to protect the underbelly....
and scraping LIGHTLY there happens occasionally.
yes clearance can be an issue with steep angles...
take them obliquely. take them slowly. take another route.
is your hitch properly sized so the trailer is level?
bigger tires not a good idea and your axles aren't old enough to be sagging...
8-10 inches is about normal as i recall and dragging isn't common
take a few pictures and post them...may get ya more help seeing it.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 12-03-2006, 12:31 AM   #3
Hi 2air', many thanks for the reality check. I'll definitely remove the little buggers and take it slow and easy. Sounds good - I'll post a few pics when I get back. peace out , Greg
Old 12-03-2006, 04:04 AM   #4
Steve Heywood's Avatar
Profile:  1997 30' Excella
Buckeye , Arizona
I've towed my 30' Excella for the past 30 months and nearly 10,000 miles. I've drug the back of my trailer ONCE! If I had wheels on the bottom of my frame I would have drug it many times.
Steve Heywood
Buckeye, AZ
2005 Ford F250 CC Powerstroke
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 12-03-2006, 06:20 AM   #5
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Yea, I have a set of thsoe wheels. Brand new still in the box! When putting together our STUFF while waiting for our AS, they looked like a good idea. Once I went to install them it all started making no sense at all. Why would I want to decrease my ground clearance. Anybody want a complete set still in the box?
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-03-2006, 06:55 AM   #6
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
nope, i'll keep the casters on my roll away tool box.
airstreams have a pair of skid plates at the rear of the frame. they are simply a "c" channel welded to the bottom of the frame.
in my view they are a consumable item, mine are rounded off at the rear from occasional drags. if i ever wear them off to the point of needing replacement i'll just weld new ones on.
john
you call them ferrets, i call them weasels.
Old 12-03-2006, 06:56 AM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
Yes to all of the above! I learned this early and there are some gas station entries that I no longer attempt. Taking it slow will prevent bounce from contributing to the drag. And going in at an angle does improve the geometry. Sorry hearing about the damage.
BobStream
...You really don't know someone 'til you've had recess with them. ...Alex Ziton, age 8
Old 12-03-2006, 08:08 AM   #8
Profile:  1977 31' Sovereign
McHenry , Illinois
My skid plate part of the frame on my 77 31 footer are squared off. The first time I tried to back it into my uphill drive I dug a one inch deep groove into the drive (my wife was directing and failed to look down to see the problem). I fairly quickly realized it was taking too much power to back up and got out. No damage to the unit and now I take the W/D bars off before I back in and that gives me enough clearance. I also drop them if I am backing into an uphill camping site. Sometimes the little dips fool you but you will learn what situations to avoid.
dwightdi is online now   Reply With Quote
99 30' Excella weight Santa 1997 -2001 Excella 4 08-02-2008 02:04 PM
Approx value of 95 Excella 30' tslanier Trailer Values 4 06-03-2006 06:00 PM
New Floor in a 30' Excella Steve Heywood Repairing/Replacing Floor &/or Frame 0 05-15-2006 09:23 AM
Looking at a 2000 30' excella jrasky Trailer Values 3 03-19-2006 10:09 AM
30' Excella for sale k5cad For Sale & Wanted 0 09-01-2003 05:30 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
