Old 10-10-2012, 02:13 PM   #1
195Pilot's Avatar
1975 31' Sovereign
Pierre , South Dakota
Door jamb too wide after shell off.
After welding up new frame I copied as much of the old subframe as possible. Basically the rear 2 Ft. and the front curves were mush. I installed the new subfloor, leaving the front and rear long to scribe to fit. After a couple of scribe and cut I have a very good fit on both ends of the subfloor.
I have center lines on frame, front hold down plate and subfloor, and trailer shell front and rear, all line up within 1/16"
The problem I have is with the door, door jamb margins. The front off hinge side, the door just touches the jamb large margin 5/8". Hinge side of the door has 1/8" to 3/16" margin. Also the door is scrubbing the threshold.
Now in retrospect before the shell off I knew I had problems in this area as there was a wide margin at the front of the door and the threshold of the frame was cracked front and rear. My intentions were to fit everything up and then before final assembly weld up threshold.
In picture 1 you can see the center line of the hold plate.
In picture 2 notice the wide door margin to the front and the door scrubbing the threshold.
The 3rd and 4th picture show the threshold.
I have added other pictures to show the overall position of the shell and subfloor fit.
So I guest my question is how do I go about reducing the door jamb margin on the off hinge side?
Jack
ID:	169982   Click image for larger version
ID:	169984   Click image for larger version
ID:	169987   Click image for larger version
ID:	169989   Click image for larger version
195Pilot is offline   Reply With Quote
Old 10-10-2012, 02:53 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
If you mean what I think you mean, in that the door frame is out too far at the floor, you have the exact same problem we had. The plywood floor needs to be notched to allow the door frame to slide in far enough so the threshold meets the plywood. When we installed our plywood floor, I missed the two notches for the door frame. I don't have exact measurements for you, but I think the notches were about 3/4" wide and 1/2" deep. The two holes in the threshold need to line up with the holes in tip of the outriggers under the door.
Old 10-10-2012, 05:39 PM   #3
195Pilot's Avatar
1975 31' Sovereign
Minno,
I missed that dado in the plywood for the door threshold. I will cut that out tomorrow and hopefully that will square up the door frame.
All the plywood around the door was gone long before I started this project. I keep laughing at myself, when I bought this project I told myself "One sheet of plywood in the rear, spruce up,clean up and we're camping".
But I have gotten a real good airstream education. As a matter of fact after I complete the plumbing I will apply for my PHD in AIRSTREAM REBUILD.
Old 10-10-2012, 06:22 PM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Bzzt. Your next step is to compete in the selection process for an unpaid Intern position for 200 hours of gopher & polishing duty in hopes to be selected for the seven year apprentice program that grants the eligibility to apply for upper-level programs.
I also skipped notching the floor for the door but the '73 27' floor was nearly one-inch off center as-found, and when that was corrected (negotiated) everything lined up within 1/4" or so and all dimensions on the two-hinge door-to-frame seem as workable as original. There may* be a mild flare or barely noticeable profile change of the shell at that point but it's locked into the outriggers for keeps... Only time will tell if I dood wrong
Old 10-10-2012, 06:33 PM   #5
195Pilot's Avatar
1975 31' Sovereign
I completed my 200 hours of unpaid internship the first week. I would like to submit my year and a half Cessna 195 AIRCRAFT POLISHING Duty. I understand that those credits will transfer
Old 10-10-2012, 06:40 PM   #6
195Pilot's Avatar
1975 31' Sovereign
In reviewing my credits for PHD I realize I will have to take Zip DEE Remove, Reinforce, and replace 401 before I can submit my application.
Old 10-10-2012, 07:00 PM   #7
Wabbiteer's Avatar
1972 29' Ambassador
We're sorry - that 200 hours is in semester credit hours which corresponds to 15 contact hours per semester credit hour. Please re-apply in another 2700 hours...
One sheet of plywood in the rear, spruce up,clean up and we're camping..
Yup. First thing I bought for the trailer were some packs of engineered wood flooring for the bath area, bought from the 're-use store' - that are now sleeping in a landfill somewhere quite unused. I am afraid I am living proof the road to 'Streamin is paved with good intentions....
Old 10-11-2012, 06:39 PM   #8
Phoenix , Arizona
I think that anyone who successfully completes a "shell off" restortation of an AS trailer deserves to have a PHD in "Airstream Rebuild".
I'll bet that there are more than twice as many "shell off" restorations that are started than are completed.
M2HB is offline   Reply With Quote
Old 10-16-2012, 06:42 PM   #9
195Pilot's Avatar
1975 31' Sovereign
Well after removing the shell and cutting out for the door sill plate, The door to door Jamb margin is still 3/4 inch at the bottom on the front side of the door. The rest of the door margin is approx, 1/8"/At the front of the door at the top it has a good margin then expands as it goes down to 3/4".
I'm out of ideas. Anyone have suggestions?
Jack
Old 10-16-2012, 07:04 PM   #10
Wabbiteer's Avatar
1972 29' Ambassador
Could this be an incidence of the hinge pin being worn and just coincidentally it's bound and rotated to amplify the lean?
Old 10-16-2012, 07:11 PM   #11
reinergirl's Avatar
Hollis , New Hampshire
I'm having trouble envisioning exactly where your gap is... Is it possible the frame of the door got warped?
And the trailer is completely level right?
reinergirl is offline   Reply With Quote
Old 10-16-2012, 09:50 PM   #12
195Pilot's Avatar
1975 31' Sovereign
I checked the hinge pins, grab front bottom of door and pull up very little movement, Also checked for hinge alignment, screws tight, no play in hinge for adjustment that I can see.
The front of the door at the bottom is 3/4" from the door jamb when closed, you can see inside the trailer at the bottom of the door 3/4" gap.
It is possible the door frame is racked, and I thought no problem just drill out door jamb and square it all up and install. Only problem is the door opening was cut to large to start off, the rivets are barely catching the side sheets of aluminum, any movement to square up the door and there will not be aluminum to rivet into, in aircraft terms there is NO edge distance in the aluminum/rivets.
Before shell off there was a large margin, but everything was rotten/rusted underneath so I assumed once a solid foundation was established the door would square up into the door jamb.
Old 10-17-2012, 03:05 AM   #13
Oklahoma City, Oklahoma
KathrynOKC's Avatar
Oklahoma City , Oklahoma
I see most of you guys doing these shell offs are going for your PHD's. I wish I could but I don't see how I could every get it done. Maybe the next owner will tackle it.
If the floor falls out of mine I'll grab some friends and we will Fred Flintstone it down the road.
All joking aside you guys have earned my respect .
Kathryn
Oklahoma City, Ok
1963 26ft Overlander
KathrynOKC is offline   Reply With Quote
Old 10-17-2012, 06:30 AM   #14
reinergirl's Avatar
Call it in or post it to the VAP's Facebook page. I think they are broadcasting tonite and its a good question for Colin.
theVAP - The Vintage Airstream Podcast | Facebook
Finally some pics of my shell off P&K Repairing/Replacing Floor &/or Frame 52 01-06-2012 04:30 PM
Expansion anchors instead of elevator bolts for shell on floor replacement? timzog Repairing/Replacing Floor &/or Frame 4 12-12-2011 05:43 PM
Shell Off Question Evets Repairing/Replacing Floor &/or Frame 8 10-29-2011 07:36 AM
1970 Shell Off Questions P&K Repairing/Replacing Floor &/or Frame 1 07-22-2011 07:22 PM
Shell removal confusion P&K Repairing/Replacing Floor &/or Frame 6 05-21-2011 06:32 PM
