Old 11-08-2012, 09:53 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
I am curious what others have used to cut out sections of damaged flooring. With all the new types of tools available (battery circular saws, Rotozip, Dremel, oscillating saws) there certainly are a lot of options. Any thoughts or pictures?
Thx!
Indiana, PA
Roadrunner is offline   Reply With Quote
Old 11-08-2012, 10:23 AM   #2
1981 31' Excella II
New Market , Alabama
For small areas I use a Dremel Saw. It is a vibrating thing that I like to refer to as a bone saw. You can make plunge cuts with it without worry about hurting what is underneath. Once you get a decent size hole, you can use a jig saw or a saws all. If the floor is rotten over a large area especially at the back, consider a more permanent repair.
Dremel 6300-05 120-Volt Multi-Max Oscillating Kit - Amazon.com
Perry
Old 11-08-2012, 10:56 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
A circular saw (battery or plug-in), set the thickness of the plywood, will probably give you the straightest and cleanest cut. Assuming you want a straight cut that is. Setting like this will let you cut over the top of the framing members without damaging them or the saw. Use it to cut as close to the corners of the opening as you can, and then use a jig saw, oscillating saw, or even a saws-all to finish the corners. I would use an oscillating saw if the corner is on top of the frame.
Chris
Old 11-08-2012, 02:56 PM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
My flooring is OSB. I just scooped out the damaged area with a big spoon. I did trim around the edges of the hole with a jig saw.
Old 11-08-2012, 03:57 PM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I use a sawzall most of the time.
A harbor Freight multi tool is very useful also as you can plunge cut around the bolts and then cut off the bolts after the big pieces are removed
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
