Old 01-04-2015, 04:07 AM   #15
chaseav's Avatar
2015 25' FB International
Yes, apparently putting the jacks down is torquing the frame and the stuff attached to it. When you applying a force that would counter that torque, a squeaking / moaning / thunk / thud sound is made. Question is, how does one stabilize the rig evenly? Someone on this thread suggested jack to the ground then half a turn. I'm currently more like four turns but I don't think evenly. Hence the problems though at the moment they are pretty minimal. I'm going to put a torque meter on it and come up with a hard number that minimizes the squeak. (I originally thought these jacks were used to lift the weight off the wheels entirely. The dealer quickly corrected me on that and said just a couple turns.)
chaseav is offline   Reply With Quote
Old 01-04-2015, 12:58 PM   #16
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the first thing you need to do is to understand that these are not JACKS; They are STABILIZERS. I start in the back because the tongue jack holds the front of the trailer and levels it. Level the trailer, lower rear stabilizers, then lower front stabilizers. On a hard surface like concrete or asphalt, I go 1/2 turn after it hits the ground. In dirt, or on grass, I might go one full turn.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-04-2015, 02:32 PM   #17
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
As Bob says, there are no leveling jacks on an Airstream, only stabilizers. To level the trailer side-to-side, you must use either lumber or Legos or other plastic leveling device. Front-to back leveling is done with the tongue jack.
Once you have the trailer level, put the stabilizers down to keep the trailer from rocking on the suspension. I operate my stabilizers with with a cordless drill. The drill is set a a satisfactory torque setting which allows me to lower each stabilizer with the same amount of force.
If stabilizers are set down with too much force, the frame of the trailer will be torqued or twisted slightly causing all sorts of strange misalignments with the trailer.
Brian
SuEllyn & Brian McCabe
Old 01-21-2015, 05:27 AM   #18
chaseav's Avatar
I guess what I was always thinking is that the jacks (which are what those units ARE regardless of what they are referred to and their intended use) were there to level the AS on unlevel ground. Basically what an outrigger does. They even have the same articulating foot / pad on the bottom. I'll let Airstream know they should make they electric and self leveling .
Old 02-23-2015, 02:54 PM   #19
LOGRIDER's Avatar
2014 27' FB International
Avila Beach , California
Dkottum,
Could I trouble you to send me a photo of the two recliners you placed in your unit. I have been searching the forums for an hour in an attempt to find them again, but no success. If you'd like you may e-mail them to dpallab@charter.net
Logrider
"don't let life get in the way of living"
LOGRIDER is offline   Reply With Quote
Old 02-23-2015, 06:13 PM   #20
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
The '15 Classic does come standard with electric stabilizers. Since I haven't used them much don't have experience on how much torque is dialed in....but on my '12 28' Intl I had to be careful not to crank them down with a lot of force (using the electric drill I'd go about 50% of the available torque). Any more than that and I could just about predict that I'd have door closing issues. Will be interesting to see how much torque is dialed in with the Classic for soft, semi-soft, etc. surfaces.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 02-23-2015, 10:24 PM   #21
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Our 1999 34' flexes... yes... So, that is just her way to 'PURR' for ya...
Peace and Blessings..
Channing
WBCCI# 30676
Newly creaking floor in our new trailer... Rocinante General Repair Forum 5 04-17-2014 12:25 AM
Creaking floors wmarsha 1998 Excella 1000 3 01-16-2013 07:52 PM
Creaking Floor SilverCabin General Interior Topics 2 05-22-2009 10:04 AM
'99 25' Safari water leak driving me crazy Raptorrider2001 1999 Safari 4 12-06-2002 06:34 PM
Crazy or not? philipbarrett Airstream Motorhome Forums 7 06-29-2002 09:19 PM
