Old 12-05-2003, 03:17 PM   #1
JLD
Profile:
Couch Repair
I have a lovely couch that looks a lot like the one Scott pictured in the Flooring project thread. The fabric is in great condition, but the couch itself is a bit like sleeping on a hilltop when it is "flattened" into a bed. It is double bed size. Has anyone encountered this problem and been able to repair the couch so it lays flat enough to make a comfortable bed. Right now only one person can "comfortably?" sleep there. The person on the inside finds his/her bed sloping into the wall. The person on the outside is flatter, but may end up on the floor if they turn over in a hurry. If they turn the other way they end up on top of the downhill person. ARRRRGGG. The strange thing is it is perfectly comfortable to sleep on for one person when it is in the couch configuration. Also, Scott's picture shows storage bins under the couch, whoooooeeee, space for bedding under the bed.
Has anyone installed, fixed, whatevered one of these? Ideas?
JLD
"Wisely and slowly. They stumble
that do run fast."
Wm. Shakespeare
JLD is offline   Reply With Quote
Old 12-05-2003, 03:27 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Hmmm...
Is it possible that your couch isn't an Airstream original? Every front couch I've seen has some sort of storage underneath it, whether it is a hinged, sliding or roll-up tambour doors. The exception being when there is the water tank underneath...like on our side one. Our front couch had storage, which we modified when remodeling for the dinette.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 12-05-2003, 03:30 PM   #3
Moonshot
The Painted Pig
Moonshot's Avatar
Profile:  1979 Argosy Minuet 7.3 Metre
East Central , Alabama
Images: 14
Hi JLD,
Thanks for the compliments on my 63 Tradewind, which I sold last year. I have a very similar setup in my 79 Argosy (which is also 24').
I'm not sure whether this is your issue, but when I pull my gaucho out into a bed I usually have to lift up a bit. If I pull it out too far the slide mechanism will go over the front of the gaucho (the piece just above the storage bin) and the front of the seat cushion sits too high. So, I wind up pushing it back in a tad and it falls down into place.
HTH
Scott
Moonshot is offline   Reply With Quote
Old 12-06-2003, 12:55 AM   #4
JLD
Profile:
Talking
Hi Scott. I think you are right. This couch is a replacement for the original, but the owner had them put in one that is just like the original with the exception of the storage space underneath, boo hooo. It never dawned on me I was pulling it too far out. The old owner said it was comfortable and when I did a test drive I thought he mustabeen a contortionist or paralyzed from sleeping on the rack. Now I know what is wrong with my picture. JLD
that do run fast."
Wm. Shakespeare
Old 03-26-2004, 03:29 PM   #5
j&jsoldsilver
j&jsoldsilver's Avatar
Profile:
Couch repair
Our sovereign couch has a sag problem when extended into a bed. I plan to replace the thin luan which supports it over the aluminum supports with 1/2 inch plywood. Has anyone done this
successfully?
j&jsoldsilver is offline   Reply With Quote
