I recently laid some cork flooring down in my '67 Safari.I had never done any sort of flooring work before,so was pleasantly surprised at just how easy it was.
While cork was not,by any stretch of the imagination,an originall A/S floor option,it just seems so ideal for trailers,given all it's pros i.e.flexibility,moisture resistance,durability,warmth etc.
I am very happy with how it turned out.Now just hope I can get this photo to attach!
Great job on the cork Charlotte, I used to install flooring for a living am impressed with your results. I look forward to seeing it in Bellingham in August.
Really like the look of your cork flooring. How hard was it to install (what steps did you need to take)? We have whatever vinyl came standard on the 1979 models and then one of the previous owners screwed a carpeting remnant (dark brown - ugh) down the length of the trailer. Want to remove carpeting and install flooring that will be more appealing and kid friendly. Cork looks like it might be the answer. AJ
I really like the idea of cork flooring. We have been planning to replace our old and original shag carpeting in our 72 AS with Berber. The cork sounds great!
I understand that we should be very careful to let the floor breathe and not seal it with any sort of non-breathing membrane. Is that true? Does the cork breathe or is the adhesive backing likely to seal up the flooring underneath and give problems?
I have been told that AS have marine plywood floors that must be allowed to breathe from the top as well as the bottom. I look forward to feedback on this issue.
I am thinking of replacing my carpet with cork tiles. After researching I discovered that cork comes 2 ways: prefinished and you still have to put on some sealing polyurethane coats or raw and you have to apply many sealer coats. Flooring dealers in my area only handle the prefinished kind as they say that's the only kind they can guarantee. What kind did you lay? Also--did you seal the subfloor first? Thanks. I would appreciate hearing the particulars.
I'm seriously replacing the carpet in just the galley area of my International with cork tile. The galley is currently carpeted and I still have the plastic on the carpet, but I know that can't last.
The galley has a lot of curves and angles. It seems to me that cork would be a lot easier to fit than something like Pergo. Also, due to the angles, I can't use a base molding to cover expansion space. Cork tile should have enough give to allow me to fit it closer to the baseboard.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
I haven't yet decided on a replacement for my flooring, but that cork sure does look good. What about ribs in the floor? The carpet in my motorhome is padded well underneath, and I recall peter saying he floated some bondo or some stuff under his pergo to smooth out the floor. Can you put the cork down directly, or what goes under it? Thanks- by the way nice photos.
Sorry for taking so long to reply to the cork floor questions.Spending far too much time lately working the exterior polishing!
I elected to use the unfinished cork,which requires me to apply the glue and then seal the entire floor with urethane.I went this route for two reasons...1) it provides a completely sealed finish(in case of leaks,spills etc.)and 2)it can be re-sealed years down the road,while the pre-finished ones cannot.
I removed all the old tiles and found that my subfloor was in nice shape.Gave it a solid sanding down first(no need to seal it with anything) and then applied the glue.Next,you lay the cork tiles(in my case,I elected to use cork planks),roll it with a lino roller and then I applied 3 or 4 coats of urethane finish.Allow it to dry and voila,you got yourself a "new" floor!
Been using it now for about 4 months and am super happy with it.Not cold on the feet when the outside temps are on the cool side;very durable and easy to keep clean.
First let me say your floor looks marvelous! Is the cork porous? Does it have deep pockets or dimples in the surface? Do you have to glue the seams together?
The nature of the cork's surface will totally depend on what type of cork you buy.The company I purchased mine from had at least 10 different types of cork...some with smoother surfaces than others.Mine is slightly uneven to the finger touch,but nothing you would notice as you walk on it.
You do not have to glue the seams together.The glue that you apply to the entire subfloor before laying the cork down holds everything in place.The seams are sealed from the top by the application of urethane to the entire surface.
