Old 04-09-2002, 04:29 PM   #1
Charcigar's Avatar
Profile:  1967 22' Safari
Coquitlam , Beautiful BC
Cork floor
I recently laid some cork flooring down in my '67 Safari.I had never done any sort of flooring work before,so was pleasantly surprised at just how easy it was.
While cork was not,by any stretch of the imagination,an originall A/S floor option,it just seems so ideal for trailers,given all it's pros i.e.flexibility,moisture resistance,durability,warmth etc.
I am very happy with how it turned out.Now just hope I can get this photo to attach!
Charcigar is offline   Reply With Quote
Old 04-09-2002, 04:30 PM   #2
Charcigar's Avatar
Trying again to attach picture...if this does not work,I give up!
Old 04-09-2002, 09:32 PM   #3
66TradeWind's Avatar
Profile:
Images: 22
Nice job !
Great job on the cork Charlotte, I used to install flooring for a living am impressed with your results. I look forward to seeing it in Bellingham in August.
Terry O'Neill
Calgary, Alberta, Canada
WBCCI 4786
VAC
http://pages.sprint.ca/Streamsite/main.html
66TradeWind is offline   Reply With Quote
Old 05-16-2002, 10:34 AM   #4
montanaandy's Avatar
Profile:
Thumbs up Cork Flooring
Really like the look of your cork flooring. How hard was it to install (what steps did you need to take)? We have whatever vinyl came standard on the 1979 models and then one of the previous owners screwed a carpeting remnant (dark brown - ugh) down the length of the trailer. Want to remove carpeting and install flooring that will be more appealing and kid friendly. Cork looks like it might be the answer. AJ
montanaandy is offline   Reply With Quote
Old 07-18-2002, 08:29 PM   #5
Profile:
I really like the idea of cork flooring. We have been planning to replace our old and original shag carpeting in our 72 AS with Berber. The cork sounds great!
I understand that we should be very careful to let the floor breathe and not seal it with any sort of non-breathing membrane. Is that true? Does the cork breathe or is the adhesive backing likely to seal up the flooring underneath and give problems?
I have been told that AS have marine plywood floors that must be allowed to breathe from the top as well as the bottom. I look forward to feedback on this issue.
By the way, where did you find the cork flooring?
Our real estate site is:
http://www.Kate-Jody.com
Mr Jody Hudson is offline   Reply With Quote
Old 07-18-2002, 09:38 PM   #6
Profile:  LOST , Hawaii
Globus cork
Jelenik
Both of them have some pretty good info, installation, maintenance, and finished floor pictures.
John
74Argosy24MH is offline   Reply With Quote
Old 07-18-2002, 10:08 PM   #7
Profile:
Thank you very much!
Old 07-28-2002, 01:08 PM   #8
jeanarlene
Profile:  1971 23' Safari
Lake Ann , Michigan
I am thinking of replacing my carpet with cork tiles. After researching I discovered that cork comes 2 ways: prefinished and you still have to put on some sealing polyurethane coats or raw and you have to apply many sealer coats. Flooring dealers in my area only handle the prefinished kind as they say that's the only kind they can guarantee. What kind did you lay? Also--did you seal the subfloor first? Thanks. I would appreciate hearing the particulars.
Jeanne
Jeanarlene
jeanarlene is offline   Reply With Quote
Old 07-28-2002, 01:55 PM   #9
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Cork tiles
I'm seriously replacing the carpet in just the galley area of my International with cork tile. The galley is currently carpeted and I still have the plastic on the carpet, but I know that can't last.
The galley has a lot of curves and angles. It seems to me that cork would be a lot easier to fit than something like Pergo. Also, due to the angles, I can't use a base molding to cover expansion space. Cork tile should have enough give to allow me to fit it closer to the baseboard.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 07-28-2002, 06:08 PM   #10
GA Airstreamer Air_005
Profile:  North , Georgia
I haven't yet decided on a replacement for my flooring, but that cork sure does look good. What about ribs in the floor? The carpet in my motorhome is padded well underneath, and I recall peter saying he floated some bondo or some stuff under his pergo to smooth out the floor. Can you put the cork down directly, or what goes under it? Thanks- by the way nice photos.
Old 07-29-2002, 12:50 PM   #11
gwsullivan's Avatar
Profile:
Cork floor
Great looking floor!! Did you glue the cork down or use the "floating floor" type??
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 07-29-2002, 06:19 PM   #12
Charcigar's Avatar
Sorry for taking so long to reply to the cork floor questions.Spending far too much time lately working the exterior polishing!
I elected to use the unfinished cork,which requires me to apply the glue and then seal the entire floor with urethane.I went this route for two reasons...1) it provides a completely sealed finish(in case of leaks,spills etc.)and 2)it can be re-sealed years down the road,while the pre-finished ones cannot.
I removed all the old tiles and found that my subfloor was in nice shape.Gave it a solid sanding down first(no need to seal it with anything) and then applied the glue.Next,you lay the cork tiles(in my case,I elected to use cork planks),roll it with a lino roller and then I applied 3 or 4 coats of urethane finish.Allow it to dry and voila,you got yourself a "new" floor!
Been using it now for about 4 months and am super happy with it.Not cold on the feet when the outside temps are on the cool side;very durable and easy to keep clean.
I'm sold on cork!
Old 07-29-2002, 06:47 PM   #13
74Tradewind's Avatar
Profile:
Cork Flooring Question
First let me say your floor looks marvelous! Is the cork porous? Does it have deep pockets or dimples in the surface? Do you have to glue the seams together?
Thanks, Brian
www.ISellThousandOaks.com
74Tradewind is offline   Reply With Quote
Old 07-29-2002, 07:25 PM   #14
Charcigar's Avatar
Brian,
The nature of the cork's surface will totally depend on what type of cork you buy.The company I purchased mine from had at least 10 different types of cork...some with smoother surfaces than others.Mine is slightly uneven to the finger touch,but nothing you would notice as you walk on it.
You do not have to glue the seams together.The glue that you apply to the entire subfloor before laying the cork down holds everything in place.The seams are sealed from the top by the application of urethane to the entire surface.
Hope this helps.
Pingbacks are On
Cork floor Pahaska Floor Finishes 73 Yesterday 01:46 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
repairing floor rot danesh Repairing/Replacing Floor &/or Frame 18 02-03-2004 09:34 PM
19' Bambi cork floor need sq. feet of A/S JimBrownUT Floor Finishes 4 01-07-2004 05:26 PM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 06:28 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
