Old 01-22-2013, 11:19 PM   #1
1962 19' Globetrotter
Vancouver , British Columbia
Connecting subfloor to u-channel
Hey guys
For those that secured the subfloor recently, what did you use for bolts?
I have elevator bolts to secure to the frame but need to know if the same bolts are used for the u-chann?
Thanks in advance
Stupidnoob is offline   Reply With Quote
Old 01-23-2013, 05:31 AM   #2
Always learning
Lance M's Avatar
1972 29' Ambassador
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Hello stupidnoob
For bolts that go through the U channel, sub-floor and outriggers/front and rear cross members, I use a 1/4"-20 hex head bolt with a thick fender washer or a piece of 1/4" thick aluminum plate under the bolt head.
In the curved areas of the corners that secure the U channel to the sub-floor only, I use an E bolt.
Enjoy your project!
Lance
Lance M is offline   Reply With Quote
Old 01-23-2013, 07:05 AM   #3
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Top,
So you are using 1/4"X..... " to hold the floor to the frame? The.... are what length?
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 01-23-2013, 07:11 AM   #4
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Oops. Sorry.
1/4"-20x2"
Lance
Old 01-23-2013, 10:27 AM   #5
Makes sense now, thanks for the heads up, just need to find more of that u channel mines all busted up
