Old 09-09-2008, 08:00 PM   #1
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
Check out my floor rot!
well i decided to tear out the front of my airstream to find a leak in the front, pop out a big dent in the front of my airstream. fix some floor rot and and change the floor covering in the front of the trailer.o and fix the cracks in the plastic trim in the front of the trailer were the radio is(thats getting replaced aswell). I just wanted to show everyone here what am doing and hear some suggestion's on fixing the floor. i think am going to patch the floor since the rot is right over a brace.
Name:	airstream teardown 001.jpg
ID:	67154   Click image for larger version
Name:	airstream teardown 002.jpg
Name:	airstream teardown 003.jpg
ID:	67156   Click image for larger version
Name:	airstream teardown 004.jpg
osolow is offline   Reply With Quote
Old 09-09-2008, 08:15 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Airstream uses partical board flooring ??
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-09-2008, 08:39 PM   #3
on the hunt
osolow's Avatar
riverton , Kansas
yes they do they did in my 1990 29fter any way.
i figure after i patch the rot i have now aim going to get some of that floor epoxy to roll on it when i am done
Old 09-09-2008, 08:41 PM   #4
soldiermedic's Avatar
Florissant , USA
Airstream did use OSB for some years. Dreadful stuff since it disintegrates with water.
Bummer D.
You need a leak checker? Leak Finding for RVs
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 09-09-2008, 08:46 PM   #5
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
I'd heard rumors that Airstream used particle board at one time. Guess this confirms it. The epoxy sealer sounds like a good idea.
Traveling With Elvis
life with a 1956 Sovereign of the Road
• • • Aluminocentricity • • •
Sugarfoot is offline   Reply With Quote
Old 09-09-2008, 08:55 PM   #6
on the hunt
osolow's Avatar
riverton , Kansas
iam just glad it's just a couple of small spots in the front of the trailer.
i havent seen any signs of rot any were else thankfuly.
but like i said earlier i going to look around this forum because i dont remember what the wood epoxy is called but I am going to put it down and hopfuly keep from haveing the any more floor rot in the front any way.
the big problem is going to fix the plastic end cap it got like a dozen cracks in it, I think iam going to try fiberglassing it to fix it?
Old 09-09-2008, 09:01 PM   #7
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
If you want to just patch rather than replace you can do this.
Take fiberglass cloth 1 or 2 layers and coat in MAS fiberglass 2 part resin, it will last laonger than the wood around it.
'77 Sovereign Intl 31' CB
Old 09-09-2008, 09:11 PM   #8
on the hunt
osolow's Avatar
riverton , Kansas
sounds good
but i would think it would work good in the small spot by the door,
but but the top two pic are pretty large roted areas.
another question were would be a good place to pic up the plastic trim for the front windows the plastic is hard and broken in a few places or would i have to call a dealer and hope the can still get parts for my 90?
Old 09-10-2008, 06:24 AM   #9
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Airstream may still use particle board (aka OSB) in the entry level Airstreams....I believe the 16' and 19' did even as recently as a few years ago...might still be the case...I think, the 22' units did too. Not sure anymore if they still do and if that has been extended to the 23', but I am sure someone here could say for sure that has been out to JC recently.
Attached was a trip I took to JC in December 2003. It shows a 16 or 19' unit with OSB.....I have another pic of a widebody and that is regular plywood....
ID:	67175   Click image for larger version
Old 09-10-2008, 06:35 AM   #10
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Git-Rot is the stuff that boat restorers use. Many on this Forum have used that product as well.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 09-10-2008, 06:39 AM   #11
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Osolow,
I think the trade name I have heard around here is ROT DOC. I have also used Minwax Wood Hardener with petty good results. the wood hardener will work as long as the fooring is still intact. It basically soaks into the wood fibers and hardens.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-10-2008, 07:05 AM   #12
Over59's Avatar
Putnam , Connecticut
Images: 37
Some of this board is near marine quality for water resistance, some is near cardboard. Have you found the leak yet. The water is likly getting into the board from between the walls, on the edge where this stuff is most vulnerible. What condition is the frame member under that rot? Since you have it apart you have an opportunity to repair it before it gets worse. Prehaps some Por-15 is all it needs or a bondo stlye patch. You see under that wet floor is a layer of fiberglass. You may be able to tell from the edge of the flooring if the leak got to the glass and then sat on the frame nice and wet.
Check with a good marine supplier for which penatrating epoxy will actually penetrate the flooring, it may be treated and not let the epoxy in.
Why is the end cap cracked? That's a little unusual. Do a little test with a good two part epoxy (like a teaspoon) to test for adhesion. (Follow the mixing directions for temperature) By the way these are the hardest part to get back on if removed.
Good Luck, should keep you out of trouble this winter.
Over59 is offline   Reply With Quote
Old 09-10-2008, 07:20 AM   #13
BDandTTs's Avatar
2005 22' International CCD
Huntington , Vermont
Images: 49
We used GIT-ROT and epoxy paint
We found similar areas in our 2005 22' CCD. In our case the OSB flooring was damp or showed evidence of previous dampness, but was not punky. See post #4 in this thread, http://www.airforums.com/forums/f223...ccd-44473.html
Make sure that you clean and dry the flooring before attempting any repairs. We vacuumed and used soap and water to clean, then dried the area with a fan for several days. Bob drilled holes in the OSB and applied "GIT"-ROT penetrating epoxy from West Marine. He also painted the area with Easypoxy Undercoat paint (West Marine) before reattaching the vinyl. Some of the vinyl had so much mold that we cut it off and threw it away, luckily it was in a storage area.
Our repair was recent, and as I've said before we're keeping our fingers crossed.
Bob, Dianne, and Tess the WFT
BDandTTs
Bandit #14576 (WDCU/AIR)
http://www.RWChatelain-Woodturner.com
BDandTTs is offline   Reply With Quote
Old 09-10-2008, 07:27 AM   #14
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If the affected area of the "wood" is only discolored the structural integrity may not have been affected but I would use the epoxy anyway. If wood is soft, the epoxy treatment won't solve the problem and you will have to cut out the rotten wood and scab in a patch. While you have the floor exposed I would use epoxy treatment on those areas of floor subject to rot: both ends of the coach, door area, around plumbing and in the bathroom. I can recommend a product called Rot Doctor. Wear a respirator it's nasty.
Floor rot in small spot! Anniedog Repairing/Replacing Floor &/or Frame 3 06-29-2008 12:31 PM
how to check for frame rot ? oldvws Repairing/Replacing Floor &/or Frame 28 03-02-2007 07:37 AM
77 Argosy floor rot kontiki Repairing/Replacing Floor &/or Frame 4 10-21-2006 06:09 PM
repairing floor rot danesh Repairing/Replacing Floor &/or Frame 18 02-03-2004 09:34 PM
Floor Rot mmeburges1 Repairing/Replacing Floor &/or Frame 3 01-10-2004 06:21 PM
