Old 09-10-2008, 08:45 AM   #15
Over59's Avatar
Putnam , Connecticut
Images: 37
Don't forget to treat the area with something to kill the bacteria that causes the rot before treating rotten wood with epoxy.
Over59 is offline   Reply With Quote
Old 09-10-2008, 09:52 AM   #16
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
thanks all this is one of the many reasons i like this site all the helpful responses
the all three spots are rotted all the way throw i will have to cut the wood out anad patch it i dont know what the frame looks like yet. i plain on lookink a liitle more tonight. i do not plain on replaceing the whole floor so unless i see signs that the frame is in bad condition. then my small foor repar will turn in to a complet frame up remodel. because if i have to fix or replace any of the frame am going to go allthe way.besides the wife is wanting to a complete redo on the bathroom
i will try to get more pic on to night that shoe the rot better
osolow is offline   Reply With Quote
Old 09-10-2008, 09:53 AM   #17
on the hunt
osolow's Avatar
riverton , Kansas
what product do you suggest for this?
Old 09-11-2008, 10:46 AM   #18
on the hunt
osolow's Avatar
riverton , Kansas
OK i need insulation advise now ? what kind ?
Old 09-11-2008, 11:14 AM   #19
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Osolow,
For this one I would go to google.com and enter something like this for a search...
insulation site:www.airforums.com
or maybe
floor insulation site:www.airforums.com
You will find a plethora of information and opinions on everything having to do with insulation.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-11-2008, 12:50 PM   #20
1995 34' Land Yacht LE
Boynton Beach , Florida
In my 1995 A/S Land Yacht, they used particle bd (OSB) flooring also. No leaks so far so it is still good. I couldn't believe for the so called quality of an A/S they did not use plywood in the MH.
JohnWB is offline   Reply With Quote
Old 09-11-2008, 02:08 PM   #21
Kevin245's Avatar
Not the Same
Particle Board and Oriented Stand Board (OSB) are completely different materials. OSB is commonly used in subfloor and roof underlayment applications. It is fairly water tolerant, thourh not water proof.
Particale board is nothiong more than saw dust, and it does not tolerate water at all. It swells and falls apart when it gets wet.
Good old fashioned plywood is still probably the best solution.
Eleanor Roosevelt
Old 09-11-2008, 02:13 PM   #22
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Check new home construction these days, same junk. Why Airstream did not stick with
plywood (should have been Marine grade) is a grand example of the bean counters ruling.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-11-2008, 05:09 PM   #23
DEITZ645's Avatar
I would agree that the floors in airstreams should be marine grade plywood, but that is probably too expensive.
When we built an addition on my mom and dad's house, we did not skimp on material and before it was under roof it got rained on. After it cleared up we broomed the excess water off. After only one small dose of water many of the plywood sheets de-laminated. The lumer yard blamed it on a bad batch from the company.
I wonder if Trex makes a plywood type underlayment material, then water would not be too much of an issue.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 09-11-2008, 06:35 PM   #24
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
I tried to find the site that soldiermedic suggested but it wouldn't load.
I'm not sure what the problem is.
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Old 09-11-2008, 06:43 PM   #25
soldiermedic's Avatar
Florissant , USA
I mistyped it.
RV leak Finding
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Floor rot in small spot! Anniedog Repairing/Replacing Floor &/or Frame 3 06-29-2008 12:31 PM
how to check for frame rot ? oldvws Repairing/Replacing Floor &/or Frame 28 03-02-2007 07:37 AM
77 Argosy floor rot kontiki Repairing/Replacing Floor &/or Frame 4 10-21-2006 06:09 PM
repairing floor rot danesh Repairing/Replacing Floor &/or Frame 18 02-03-2004 09:34 PM
Floor Rot mmeburges1 Repairing/Replacing Floor &/or Frame 3 01-10-2004 06:21 PM
