Old 08-29-2006, 10:40 AM   #1
robbp
Profile:
channel question
I need to replace flooring adjacent the door to about half way across the front while extending out about 30 inchs. I thought I would cut out the rotted area with a bevel cut on the solid interior and replace it with a matching beveled cut(sort of a plug on one side).
The question I know I have is does the wood just fit in the channel along the wall or does it get screwed/nailed into the channel? If so how do I get to it? Is there an easy way to take off the "skin"?
Thanks for sharing.
Also is there someplace that points to and/or rates other threads on their usefulness re partial floor replacement?
robbp is offline   Reply With Quote
Old 08-29-2006, 11:39 PM   #2
CaddyGrn
Profile:  1963 16' Bambi
Yreka , California
Channel...
Hello,
I am sure you have come to the right place for help! Can you provide additional information? What year/model is your Airstream you are working on? That may make a big difference in the kind of advice you need. You might also take a couple of digital pics and post them of the part you are going to remove and replace.
I know when my husband replaced our entire floor he beefed up the frame by the door as it seems to be one of the problem spots.... If your channel and floor is anything like ours, the channel sits on top of the wood (I believe...) and the floor is bolted to the frame. It is a big job.... many folks have made repairs in sections, however... I would check the search function in the blue toolbar above and key in partial floor replacement or something similar and see what you get! It will give you threads that have discussions on floors.
Here is his thread on floor replacement: you will have to scroll through a lot of pages, but he has good pictures that explain what he did...
http://www.airforums.com/forum...mbi-17925.html
Good luck!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Another Winterizing Question JWest Plumbing - Systems & Fixtures 2 11-04-2002 07:01 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question caadoptees Tires 5 07-02-2002 10:19 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
