Old 05-19-2006, 09:54 PM   #1
LTD30's Avatar
1999 30' Limited
1978 24' Argosy 24
Olympia , Washington
Thumbs up Carpet tiles are the answer.
After 3 years of full-timing and another 3 of most-timing the original shag type carpet in our ’99 30’ Limited was very stained.
We are very happy with the 3’ x 3’ modular carpet tiles that we just installed.
The tiles are industrial strength that are remnants left over from hospital, airport, hotel, etc. jobs. They are dense industrial carpet with an attached pad and a moisture barrier. You can put them down with double sticky carpet tape and then if one gets a stain you can pull it up to pressure wash or replace.
We bought 14 for $10 each from Carpet Tile Northwest in Tacoma, WA. It’s in an old warehouse garage (very low overhead). Generally the price ranges are $10 to $18 per tile depending on the thickness or size (also in 18" x 18"). The brand we got happens to be Milliken. There is a wide variety of color and patterns. Some are very garish.
We bought extra 2 extra tiles because once it is all sold you may never see it again.
Some friends installed some a year ago and are still happy with them.
LTD30 is offline   Reply With Quote
Old 05-19-2006, 10:10 PM   #2
Frank S
peoria , Illinois
Hi LTD30--I have 19-3/4" square commercial carpet tiles that have a short nap, and a firm rubber backing, in moss green. Have installed similiar tiles on a concrete floor without any type of adhesive, as long as it was tight against the walls. In the A/S may use some double side tape around the door. Will let you know how it works out when I get around to installing it later this year. Price was right, $0, as it was free leftover from a large commercial job.--Frank S
Frank S is offline   Reply With Quote
Old 05-20-2006, 09:23 AM   #3
LTD30's Avatar
1999 30' Limited
1978 24' Argosy 24
Hi Frank S, You can't beat that price - will like to hear how it turns out. LTD30
Old 12-05-2006, 08:02 PM   #4
Babeebloos's Avatar
1963 19' Globetrotter
Laguna Beach , California
Images: 24
Saw carpet tiles on HGTV...
I've been seeing more projects on HGTV where the designers are using the self stick carpet tiles. I googled them and found a few designs I liked but wanted to check with everyone here to see if anyone tried them, how they liked them, if they tripped you up on the edges, if they used glue or the self stick. Thanks, Debra
Officer says ..."Step AWAY from the toaster Ma'am"
http://www.debraschottfineart.blogspot.com
Babeebloos is offline   Reply With Quote
Airstream keys Pahaska Our Community 15 06-16-2005 09:03 PM
Is Thor/AS pricing themselves out of the TT business? John Our Community 52 12-19-2002 01:02 PM
Vista View Windows On 1979 31' Soverign montanaandy Windows & Screens 14 10-17-2002 05:03 PM
Have you ever done this?? thenewkid64 Our Community 18 10-12-2002 02:29 PM
Wheel Assembly Balancing CJsTs Wheels, Hubs & Bearings 41 09-11-2002 07:55 PM
