Old 07-24-2005, 09:52 AM   #1
1975 27' Overlander
Santa Fe , Texas
carpet glue
What are my options for flooring if previous carpet was glued down. The carpet came out good but the glue on the plywood leaves a sticky uneven surface. I was wanting to do floating cork. Any suggestions. Thanks
David Kinsey
DKinsey is offline   Reply With Quote
Old 07-24-2005, 10:57 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
carpet glue
Greetings David!
Welcome to the Forums!
David Kinsey
While I think that it would be advisable to remove the glue residue, a possible means of isolating what can't be removed would be to use the product that was used as an insulator between the composite aluminum floor and the Armstrong Laminate flooring in my Minuet. Armstrong makes a product called Quiet Step Underlayment -- it s a light-weight product designed for use with Laminate Flooring systems and isolates the Laminate flooring from the subfloor.
Good luck with your research and project!
Kevin
Kevin D. Allen
AIR #827
Old 07-24-2005, 11:20 AM   #3
1975 27' Overlander
Santa Fe , Texas
Thats kinda what I was thinking. Thanks
David Kinsey
Carpet Cleaning Advice JaceBeck Upholstery, Blinds, Walls & Interior Finishes 4 03-26-2003 10:25 AM
What is the MOST you have paid for an AIR STREAM part overlander Our Community 64 11-19-2002 05:15 PM
Termites Rob Repairing/Replacing Floor &/or Frame 7 10-25-2002 08:56 PM
Tambour Glue? 74Sovereign Cabinets, Counter Tops & Furnishings 10 10-04-2002 03:05 PM
Blinds ALANSD Upholstery, Blinds, Walls & Interior Finishes 35 04-01-2002 01:54 AM
