Old 02-04-2005, 01:23 PM   #15
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
Steph
Another solution - get another trailer to use while your fixing this one up! Thats what I have - one good one and one being restored
Ken
1958 Overlander
Ken J is offline   Reply With Quote
Old 02-04-2005, 03:32 PM   #16
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
But Ken, this WAS the good one!
Stephanie
Our family photo blog
Old 02-04-2005, 04:57 PM   #17
greg176
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island , British Columbia
I'm glad everyone else suggested you pull the belly pan. I'm not a fan of doing things half way.With the pan off you can replace the floor using proper fasteners and full sheets.You could also bring the frame to a local sandblaster and get it prepped properly.
greg176 is offline   Reply With Quote
Old 02-04-2005, 05:24 PM   #18
greg176
greg176's Avatar
Just a note. Don't be so hard on the guy who made the frame of this trailer.Because of the monocoque construction of the Airstream the frame is not designed to be the sole load carrying member of the trailer.When one part ,the floor in this case, fails the other parts have to take more load.
Old 02-04-2005, 08:30 PM   #19
Stefrobrts
Stefrobrts's Avatar
Well, this trailer has had failed floors, patches, and many trips to Alaska, so I'm not blaming anyone for anything. I just want to get it fixed up right so it can handle another 35 years of abuse.
Ask anyone who's seen it in person though, and the exterior is darn near perfect. You'd never know all that was going on underneith!
Stephanie
Old 02-04-2005, 09:01 PM   #20
rluhr
Commercial Vendor
rluhr's Avatar
2005 30' Safari
Somewhere , roaming America
That's the insidious part, I've found. My 68 Caravel looked fine on the outside but had worse floor rot than Steph's. My whole perspective on inspecting Airstreams changed when I saw mine come apart.
WBCCI #9990 | VAC | Full-timer | AIRSTREAM LIFE magazine | Tour of America weblog
rluhr is offline   Reply With Quote
Old 02-04-2005, 09:20 PM   #21
Stefrobrts
Stefrobrts's Avatar
I honestly don't know how I would pick out another AS after this. There's so many possiblities for stuff being messed up that you can't even see...
Stephanie
Old 02-05-2005, 07:07 AM   #22
greg176
greg176's Avatar
I think the best way to detect floor rot is with your nose.My sailboat had a musty smell and I assumed it was because of it's age when I first purchased it.I cleaned the inside many times and it would not go away.Later found a section of rot deep in bilge.After repair the smell was gone.
Old 02-05-2005, 12:58 PM   #23
Stefrobrts
Stefrobrts's Avatar
Ok, I hope this doesn't make you think I'm an idiot, but here's the current plan. These are tough decisions, and Dave and I have spent a lot of time discussing it and poking around in the trailer.
I'm going to leave the bellypan where it is and call out the welder and see if he can fix the exposed parts that need welding. I spent the whole morning out there cleaning up the debris, and I really don't want to remove the bellypan. It's never been off, and I'm sure I will never be able to put it back on as securely as it is now.
The floor in the rear of the coach is solid. I have poked around extensively, and can find no rot, no evidence of previous repairs. There's no reason to think the joints in the back should be broken. In the front the floor was rotted all around the preimeter, which I think allowed the extra flexing that broke the frame.
The axels are new, and were mounted to the frame rails with a new mounting plate. I can see the welds for the axels and they look very secure. The shop had the bellypan off in that area and put new bellypan panels on when they were done, and I trust they did a good job, as they came highly recommended. I don't think there's any reason to expect the axel welds to fail anytime soon.
I have a tendancy to overdo things, to make projects harder than they have to be, so I'm really shutting myself down on this one. I REALLY don't think the trailer is going to disintegrate on the road if I don't examine that last crossbeam (remember, it's a short trailer, so there's not much more behind the axels), and everything from the A frame to the axels I can confirm is in good shape after the repairs. So I'm going to fix what I can see right now and go from there.
Stephanie
Old 02-07-2005, 12:42 PM   #24
Stefrobrts
Stefrobrts's Avatar
The welder's coming in the morning. We'll see how it goes.
Stephanie
Old 02-07-2005, 06:16 PM   #25
maxandgeorgia
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
Well, we'll all be sitting with fingers and toes crossed for you, Stephanie! Report back 'cause we'll want to know how it all turned out. By the way, your reasoned decision above is well thought out. Following the track of your thinking will help others along the way when they have to weigh the pros and cons of repair. Good luck for a late winter finish to your project and a great Spring trip
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 02-07-2005, 08:52 PM   #26
Stefrobrts
Stefrobrts's Avatar
Thanks, I'm so excited I just want to go to bed so morning will come sooner! I spent about two hours in the trailer today scraping off old spray-on insulation and flaking paint, and cleaning up the areas to be welded with a wire brush. I found one more, so that's nine welds!
The guy sounded real nice on the phone, and confident he could fix the frame without damaging the bellypan, so we'll see how it goes. He's the same welder Malcolm used to fix his frame, so it won't be the first time he's seen an Airstream.
I'll let you know how it goes!
Stephanie
Old 02-08-2005, 02:53 PM   #27
Stefrobrts
Stefrobrts's Avatar
The welding is done! The guy came out this morning, got right to work on it. About an hour later he had welded all the broken places and reattached the outriggers. He fixed the step and did put one patch on a thin area. I'll take a pic after work. It's amazing to walk in it now, it's so tight, no popping and leaning. The step is solid as a rock! I'm very excited, I might really have this all done by spring!
Stephanie
Old 02-08-2005, 03:01 PM   #28
Ken J
Ahhh the ups and downs of trailer restoration...... hopefully we have more ups than downs.....
Ken
1958 Overlander
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 08:28 PM
Restoration of our Airstreamer Caravel Hagen 1965 Caravel 2 11-10-2002 02:15 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
