Old 11-22-2002, 12:17 PM   #1
Can you shorten an Airstream ?
I am looking for an Airsteam, max 22-24 ft
I found a 28ft one real cheap
NOW for the crazy idea .......
can you shorten one but taking out a couple panels 4-6 ft worth and putting the end piece back on ? yes I will shorten frame etc
I build street rods , so the work is not the problem, and the interior is bad anyway
I just do not have the room for a 28footer
Anyone done this before ?
Or does anyone know of a cheap AS thats shorter ?
Interior not important.....
oldvws is offline   Reply With Quote
Old 11-22-2002, 01:08 PM   #2
Rickk48's Avatar
Bigfork , Montana
I don't build hotrods, but I suspect that one who does would be able to shorten an Airstream. My main concern would be with overall balance, as one of the benefits of the Airstream design is the engineering that went into balancing the trailer in the design process. Don't know what price you are paying, or what year you are looking for, but Airstream manufactures lengths from 16' up, I have a 19'. It would seem to make more sense to locate a used Airstream in the length you really want, then use your skills to restore it.
Rick Klein
Seeking another Bambi
'08 Honda Ridgeline
Rickk48 is offline   Reply With Quote
Old 11-22-2002, 01:23 PM   #3
LOST , Hawaii
I removed and replaced the body of a 24 ft. motorhome in one piece, if you are good at building cars you can shorten an Airstream. The skin panels run horizontally, so you would have to cut them not remove a section, move axles, plumbing, maybe the door. On the plus it would be a great time to replace the floor and sandblast the frame. Unless they were paying to get rid of it I would seriously look for a shorter one though, it is a lot of work to pull a body.
John
74Argosy24MH is offline   Reply With Quote
Old 11-22-2002, 01:26 PM   #4
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
To balance it, you would have to cut and splice it on each side of the axles. Splice frame, plumbing, shell...evrything twice.To much engineering involved.
My answer would be no. Keep looking.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 11-22-2002, 01:42 PM   #5
its only $800.....
but its 400 miles away so I do not know the condition other than the interior is trash
Any other cheap shorter ones around ?
Old 11-22-2002, 02:30 PM   #6
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Thumbs down Nightmares
There is tons of wiring between the inner and outer shells, both AC and 12v. All this would have to be traced andspliced or replaced. Same thing for propane piping.
Next question is where would the tanks end up with all the balance and plumbing that entails.
Better to find a shorter model.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 11-23-2002, 01:26 AM   #7
Vagabond
TheBigRedTruck's Avatar
1973 31' Sovereign
Fort Meade Md. RV park slot 8!! , Motorsports Photographer
Images: 36
Send a message via AIM to TheBigRedTruck
Thumbs up
JUST GO FOR IT!!!!!!!!!!!!
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
TheBigRedTruck is offline   Reply With Quote
Old 11-23-2002, 10:01 PM   #8
Pahaska's Avatar
Hays County , Texas
Please rethink that last advice
DaPlumber
Trouble is, in practical terms, that probably would mean the loss forever of one irreplaceable vintage A/S. Better to start with a proper sized unit up front. There are enough problems restoring an old unit without trying to change the length.
John W. Irwin
WBCCI #9632
Old 11-23-2002, 10:06 PM   #9
ummm
then I better not chop the top, put louvers down both sides, paint flames and put a big wing on the back.......
just joking !
Old 11-23-2002, 10:23 PM   #10
airstreamcaravel's Avatar
I vote for "go for it"
Everytime someone trashes the originality of a vintage,
It makes mine MORE valuable!
Its your trailer, do with it as you may, BUT don't be suprised when you get funny looks from the engineers around us, and/or the preservationists!
There is also the issue of liability when your weld does not hold and the "thing" breaks in two while traveling down the road causing a multiple MVA. I would think that insurance coverage would be hard to obtain if the insurance company knew of the modifications to the structure.
On second thought .... Don't mess with it ... I might be behind you
someday.
DMC
airstreamcaravel is offline   Reply With Quote
The Official Airstream Web Site (Airstream.com) EJWeb Link Archive 3 06-11-2002 10:50 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
