Old 02-25-2010, 04:47 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Can you cut the floor around the c-channel bolts?
I'm replacing the floor along the back of the trailer. The bolts going through the c-channel (and I assume that hold the frame to the shell) are severely rusted. I was able to cut the screws, but the bolts seem impossible. Was wondering if I could just leave them and cut the new floor to fit around them. Then, drill for new bolts in another area.
adwriter73 is offline   Reply With Quote
Old 02-25-2010, 04:58 PM   #2
pbearsailor's Avatar
Port Hadlock , Washington
I sure don't think I'd want to give up the structure of the plywood by cutting it away. After I pulled my old rotted floor out, I just used my 4" grinder to cut off the old rusted bolts and pulled out the pieces with vice grips.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 02-25-2010, 05:00 PM   #3
Bo&Susan's Avatar
Daleville , Alabama
We used a sawsall and also a grinder (which ever was closest to us) to cut through them and a tap with a hammer and they drop out. Susan
Bo&Susan is offline   Reply With Quote
Old 02-25-2010, 05:18 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Be very careful with a sawsall, you can put the blade through the outside of the trailer. How do I know this?
The best way I found was to use a cut off wheel in an angle grinder. Most of the time you don't have to cut all the way through, just about 1/2 way, then you can clamp it with a pair of vise-grips and work it back and forth until it breaks off. On a couple of bolts I had used a Dremel tool with a cut off for hard to get areas. You really must get these bolts out to to the job correctly. Takes time, but worth it. Installing the new plywood into the c-channel is very difficult, I can't imagine how you could do it with the old bolts in the way.
Old 02-25-2010, 05:20 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
You will find that as the bolts were pulled down in assembly they crushed the strand board and the C channel around them will not be 3/4 so you will have to shave some wood off or cut the relieves larger the just around the bolts. You will not be able to just install other bolts at other location as the originals were into the outriggers and the flange on the tops is only about an inch wide.
I would strive to cut them out and spread the C Channel open to accept the wood.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 02-25-2010, 08:28 PM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
To put new bolts or self tapping screws in.
You need to get the banana wraps off and drill from the bottom up or the interior skin and drill down.
'77 Sovereign Intl 31' CB
Old 02-25-2010, 08:32 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Those particular bolts are 3/8" x about 3" long. You don't need to remove the banana wrap to get to them, as they are accessible through the bumper compartment. You will need to remove the interior skin, though.
Old 02-26-2010, 05:34 AM   #8
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I plunged a notch through mine alongside the bolt with a rotozip tool and a skinny 1/16" metal cutting blade - a dremel tool with the aluminum oxide cutting wheel would work too but take longer, object is to just weaken the nut enough a pair of pliers or socket will crumble it off or allow it to turn...
Old 02-26-2010, 07:43 AM   #9
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I cut around two when I replaced part of my front floor, Not ideal, but it was my first patch. I cut them out when I replace the rear floor and put new ones in. If you do cut the plywood just make sure to treat all the edges of it...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 02-26-2010, 11:23 AM   #10
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
You cut around the bolts? And it worked?
Old 02-26-2010, 01:31 PM   #11
VIKING's Avatar
Boulder Creek , California
If you read Purmans post, it sounds to me like he did this due to inexperience rather than because it's the right way to do it. How would he do it now that he has experience?
You could do what you are contemplating, but does it work?
NO!
Cut the bolts, or break them. You will do a better job if you follow the original construction. Anything else might just come back to bite you in the a$$(dollar signs intentional).
Rich the Viking
VIKING is offline   Reply With Quote
Old 02-26-2010, 03:41 PM   #12
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
NO!
Rich the Viking
Very true. I will work on it this weekend and see if I can cut them and drill them out.
Old 02-26-2010, 06:50 PM   #13
purman's Avatar
1968 28' Ambassador
If you look at my post http://www.airforums.com/forums/f44/...dor-44644.html I did it on a patch in the front. It was one of the first ones I did. The other 4 I cut the bolts and put new ones in as they hold the trailer together. Especially in the back!!!! It doesn't take that much more time. I used an angle grinder to cut them out with.
Good luck
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 02-26-2010, 10:31 PM   #14
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
will work but make sure you remove all old wood and moisture, and seal the rear wall at top of bumper enclosure real good ( point of entry for water). just got rear floor out of my 64 and used a 4" grinder with a 4" cutting wheel to chop off old bolts and screws works great and cuts through them like butter, got them at lowes about 3 bucks ea. but pay for themselfs quickly and seem to last a long time. i used a new 1 today to cut away all the old bolts on the rear 4' and still has plenty of life left.
crestonrv is offline   Reply With Quote
Nail in water line: Need to cut out floor & patch AirHeadsRus Repairing/Replacing Floor &/or Frame 12 07-17-2009 05:56 PM
Removing channel bolts Anton66 Repairing/Replacing Floor &/or Frame 10 10-30-2007 12:22 PM
cut the floor or drop the belly pan? LI Pets Repairing/Replacing Floor &/or Frame 12 09-27-2006 04:49 PM
Getting bolts out of the floor bsherman Repairing/Replacing Floor &/or Frame 35 02-16-2006 09:03 PM
hole has been cut in floor under frig silver 67 Refrigerators 4 08-16-2004 06:53 AM
