Old 06-21-2009, 11:08 PM   #1
Worldturners
tdturn2's Avatar
1976 31' Sovereign
San Antonio , Texas
Question Can we replace floor piece by piece?
We have flooring sections all over our 31' 1976 Sovereign rotted out. We've already got the marine grade plywood to replace the whole floor. Here's the question:
Can we replace the flooring sheet-by-sheet, rather than ripping it out all at once and bracing with 2x4s, etc.?
If we were to replace it sheet by sheet, would we still have to brace the floor a section at a time?
Is there an advantage to ripping out the whole floor at once?
This is our first rv, our first AS, and our first renovation of any kind. We are definitely inexperienced and are grateful for any good advice you give. We are pouring over the forums until our eyes are crossing and brains ready to burst. We decided just to ask straight-up, so sorry if we are repeating a question that's been answered elsewhere.
tdturn2 is offline   Reply With Quote
Old 06-22-2009, 06:10 AM   #2
Worldturners
tdturn2's Avatar
1976 31' Sovereign
San Antonio , Texas
Are we getting lost in the mix?
Just wanted to make sure our Q wasn't getting lost in the mix. We're new here. We had some great answers to our other question last night, but this decision is looming today, and we don't want to do something really stupid.
Does anyone have a helpful opinion? Thank you so much in advance.
- Terry and Natasha
Old 06-22-2009, 06:54 AM   #3
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
Yes, you can replace the floor sections at a time, We needed to replace the front section and the rear section, middle was fine. FIRST, you HAVE to remove the lower interior skin. Not hard get a 1/8 inch drill bit and get to work removing rivets,
NEXT you will see that the floor SLIDES into what they call the C-Channel, you will find a lot of 1/4x 20 boplts. we repalce these with galvinized ones. They are probably going to be rusty and you may need to cut them off to get them out of the c-channel, the plywood will probably disinigrate when you try and pull it out of the c-channel.
We had to replace some floor stringers and outriggers, So my husband added another stringer running from the front wall to the freshwater tank so we could replace our front floor in 2 pieces instead of the one.
You can go to the tradewind section of this forum and click onto tradewind 1970-1979 and then click onto Annette's Folley and there are pictures there on how we did this. Sometime a pictures is worth a 1000 words.
Annette
P.S. others will come along today with lots of wonderful advice, most have done what you are about to tackle.
bullydogsmom is offline   Reply With Quote
Old 06-22-2009, 08:05 PM   #4
Worldturners
tdturn2's Avatar
1976 31' Sovereign
San Antonio , Texas
Red face We're a little scared.
We really are inexperienced with this type of thing. Can anyone else give us reassurance that it is okay to do the floor piece by piece?
We are not in the position to do a whole lift-off like so many here do. Our original intention was to be full-timing on the 1st of August. We now realize that is a joke, so we are just going to get as close as possible.
We're concerned that one thing will lead to another, and we'll end up in way over our heads.
Thank you so much to anyone who sees this and responds. :-)
Natasha
Terry & Natasha Turner
'76, 31' Sovereign International Land Yacht
Remodel Madness
Old 06-22-2009, 08:29 PM   #5
pbearsailor's Avatar
Port Hadlock , Washington
Yes, it's ok. I'm in the middle of doing it that way with mine right now. I just don't have anywhere to put the shell if I took it off, my frame is in pretty good condition, so I'm definitely doing it with the shell still on. Many here have done it. Search and read the threads, like Annette's. Shari's thread http://www.airforums.com/forums/f91/...irl-31084.html is a really good one.
Problem is that it's a lot of work and it takes some money. Most of the work isn't hard to learn how to do, though, and there's a lot of support around here.
It's an opportunity to make some things in your trailer exactly the way you want them. No denying it's a bunch of work, though, and it's extremely hard to do it with time deadlines. It's been worth so much to me to read others' threads and learn from them and to understand the scope of the work involved.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 06-22-2009, 08:54 PM   #6
1965 17' Caravel
Birmingham , Alabama
Sure, I did mine one sheet at a time. Go and have a look at how RJ Dial descibes this process at www.vintageairstream.com and he walks you through it. I started at the back and moved forward but left the section at the door for last. If you don't remove the belly pan, don't be afraid to cut access holes in your bellypan for bolts. Seal and rivet the holes closed afterwards. You really should set up permanent supports under the frame and level it out. Take your time, and have fun!
gwchitty is offline   Reply With Quote
bracing, plywood, floor repair
Own a piece of history?? Airslide General Interior Topics 2 10-26-2008 11:34 PM
Patch Piece digger bear Ribs, Skins & Rivets 2 06-13-2008 05:45 PM
Two piece bath removal C Johnson 1956 - 1965 Caravel 10 04-16-2005 07:57 AM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 05:16 PM
