Today I got serious about removing the belly pan and floor in the rear of my '76
Sovereign (midBath). Was I in for a surprise... I cannot tell if my AS was in a wreck or if one of the POs added a few 'Custom" items. I was always skeptical of the hitch receiver on the back bumper. Unless someone used it for a bicycle rack, I could not see it as a good thing. Did this modification cause the rear end separation?
BTW, I removed the bumper earlier.
Could someone tell me if the mounting of this hitch receiver is common? It appears an additional rail was welded to the bottom of the stock frame. Then aluminum angles were riveted to it for the mounting of the bellypan. It took me most of the day to scrap off the Vulkem and other caulks applied as liberally as Charles Schumer.
I guess whoever did this thought the green paint would prevent everything from rusting. It didn't. They added a little corner table of steel to support the floor in the curved corner. I am not sure if this was a good thing or not. It did provide support, but it also may have trapped water below the flooring.
Notice; two of the transplant outriggers are actually ones for the step area (both right sides).
Finally... The outrigger at the rear end of the curbside wheel well looks misaligned. The photo is taken right on the edge of the outrigger, so it may be difficult to see. The wheel well moulding is offset by just over 1 1/2". The moulding has been bent outward at the bottom. Even though there was 1/2 a tube of Vulkem around the edge, there was several pounds of road mud (spun off the tires) in the belly pan next to it.
I am leaning toward taking all of this "custom rail" off and boxing the stock frame rail.
Any thoughts??
Greg
