Old 10-09-2019, 01:01 PM   #21
casarodante's Avatar
2012 31' Classic
I had a receiver welding to the A frame, but it does not have much tension on it. It is for storing my Equalizer hitch and bars.
Went to Alaska and back this summer with no issues.
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 10-09-2019, 02:48 PM   #22
1999 25' Safari
Palm Springs , California
Originally Posted by kpm View Post
I'm not qualified to respond to the welding question, but I have considerable experience installing and using my Equalizer hitch. I have used the 10000/1000 hitch on two different trailers over the past three years and never had the link plates move at all. I suspect something is wrong with your setup. Are you torquing the bolts to the correct values?
https://www.equalizerhitch.com/manua...nal-tightening
I agree, I was having trouble getting my hitch adjusted, just returned from a 2500 mile trip. I noticed the first day out that the truck and trailer smoothed out and I was comfortable with it. I mentioned to a friend that I thought the rig corrected itself. On my return I noticed the nuts were lose on the brackets on the trailer. If you weld it you won't be able to adjust the hitch. It seems the brackets on the trailer have to be at a correct angle. I maybe wrong but that is my recent experience.
RMichler is offline   Reply With Quote
Old 10-09-2019, 04:35 PM   #23
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Have you tried installing the Equalizer bracket jacket/cover? Reduces noise to nothing and ensures that bar-bracket friction is not excessive, which should reduce bracket creep.
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap,
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 10-09-2019, 05:07 PM   #24
2007 27' International CCD FB
San Diego , California
Nothing wrong with welding as it's all mild steel. A small tack weld or stop should be sufficient.
That said, one should ask why it's moving around at. Some good thoughts already on proper installation. It's designed to clamp on without any additional provisions or augmentation.
Beyond installation, one may want to ask if they're using the it properly? Is there too much tension on the bars?
What kind of tow vehicle do you run and what weight bars?
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 10-09-2019, 05:23 PM   #25
JimGolden's Avatar
1977 31' Excella 500
Doubler Plates, Longer Bolts, a Layer of Rubber....
I've been using a 14,000/1400 lb Equal-I-Zer on my Avion 34X for 13 years. I had the same problem.
It's not just overtightening the bolts. I had a smooth paint job on my frame. If I didn't tighten them down, I could move the link with my hand. If I did tighten them down, the links bow outward in the middle and it's no better, maybe worse. What was needed was Stiffness in the links and Friction against the frame.
I got four pieces of 1/2" thick plate steel (two for each side, one for each link plate), about a half inch bigger all the way around than the links. I then welded the links to these "doublers." The doublers go against the tongue, links on the outside. I then got an old truck innertube and cut some strips of rubber out that were the thickness of the tongue frame (6" in my case) by the width of my doublers. I got longer GR8 bolts to go through the now extra 1" thick assembly.
With the doublers, I was able to torque them down much tighter. No bowing whatsoever. With the rubber between the doubler plates and the tongue frame, that provided the additional friction to stop movement.
13 years and about 25,000 miles later, it doesn't move anymore. There's a thread on here somewhere from 2006 or so where I have pictures with annotations and everything. It works great.
For what it's worth, I've got a P.E. in Mechanical Engineering and have made a lot of stuff. I contacted Equal-I-Zer about this issue back in the day and told them their link plates needed to be heavier. I think they disagreed with me
That being said, other folks have welded the one piece to the tongue and you still had the adjustment up and down with the other piece. That might have been easier than what I did. But, mine works and is easily removable....although I don't see selling the trailer anytime soon. I like it too much
I think the Equal-I-Zer is a good hitch. Maybe not in the same league as the Henseley or ProPride, but at least as good as the Reese Dual Cam...which is a classic that I've used and worked well. I just don't like fighting with greasy chains. I do think their link plates should be stouter....
See ya on the road,
- Jim
JimGolden is offline   Reply With Quote
To weld or not to weld Raminc Towing, Tow Vehicles & Hitches 66 07-13-2019 05:19 PM
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 11:46 PM
water heater tank cracked. JB weld? Curtis-79MH Classic Motorhomes 12 06-09-2007 05:07 PM
freshwater tank hole.......material and plastic weld kits... leefields Fresh Water Systems 4 02-06-2006 07:44 AM
Floor Replacement - Frame Weld pinkflamingoes Repairing/Replacing Floor &/or Frame 9 01-04-2006 08:54 PM
