Old 01-27-2014, 06:56 PM   #1
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
C channel/U channel replacement
I have read several of the articles on floor repairs and riveting the body to the c channel. Can someone tell me what the thickness and grade is for the c channel being used to fasten the body down. Is their a better thickness or grade that would be better to use. Any help on this would be greatly appreciated. This Forum has saved what sanity I have during my restoration decisions. The PO lost approximately 40 ft of my c channel. Any recommendations where to purchase. What rivets are the best to reattach the body.
cole3444 is offline   Reply With Quote
Old 01-27-2014, 07:57 PM   #2
65CV's Avatar
Western , Massachusetts
I think you'll find the .032 3003 alloy, bent with the Harbor Freight Brake to be the most commonly used.
Be sure to use stainless bolts and insulate them from the aluminum to prevent galvanic corrosion.
If you like to read, check out the links here for a great set of threads.
65CV is offline   Reply With Quote
Old 01-27-2014, 08:09 PM   #3
65CV's Avatar
Oh, yeah, rivets?
See previous link to Airparts or check out VTS
If you are looking for more detail on rivets, do a search for Aerowood's posts.
Old 01-28-2014, 10:18 AM   #4
Mixter's Avatar
1976 27' Overlander
Not sure when the C-Channel changed, but you can still get the stuff for my '76 here.
For Rivets, VTS has both 1/8" and 5/32 with the matching brazier head as the original. If your rivets are drilled out nice and clean, you can stay with 1/8, but I used industry standard protocol and re-drilled and used the 5/32. You can get them here.
Make sure you get their 1/8 rivet set for the brazier head or you'll put smiley's on all of them.
Hope that helps!
Mixter is offline   Reply With Quote
Old 01-29-2014, 10:27 PM   #5
1971 31' Sovereign
1972 31' Sovereign
Thanks for the info
I appreciate the info on the type of aluminum for the c channel and I have already purchased buck rivets from VTS but your comment on the standard of using 5/32" sounds a little stronger and safer. I purchased the 1/8" but will see if they can be used on the replacement panels on the curb side.
Old 01-30-2014, 05:41 AM   #6
Mixter's Avatar
1976 27' Overlander
I believe the 1/8" are plenty strong- your whole trailer was put together with them. The reason for going up a size is because the hole gets wallered out too big and out of shape to properly make a snug fit for waterproofing. Although those rivets are soft, and fill alot of space when bucked.
Have fun!
Mic
Old 01-30-2014, 07:33 AM   #7
1974 31' Excella 500
Longview , Texas
You can buy c-channel and the prebent u-channel through Out-Of-Doors Mart. The c-channel comes in 16' lengths which can be cut in half to greatly reduce shipping cost, I'm not sure if the same can be done for the u-channel.
Ringoo7 is offline   Reply With Quote
Old 01-30-2014, 04:10 PM   #8
1972 27' Overlander
Denver , North Carolina
I just bought c channel for my 72 Overlander from OODM. 59.00. I picked it up myself.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 01-31-2014, 02:36 PM   #9
1971 31' Sovereign
1972 31' Sovereign
C Channel
Thanks mccrosti I will see if I can find it on their site, do you have a part or item number handy. Appreciate all the help.
Old 01-31-2014, 03:24 PM   #10
DanielB's Avatar
Charleston , South Carolina
I call it J-channel. I got mine from Andy at whatever place is is that is works.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 01-31-2014, 07:50 PM   #11
1972 27' Overlander
Here you go! 104463 OODM website
Good luck
Old 04-17-2019, 05:20 PM   #12
1973 Argosy 26
Ojai , California
Does anyone have the "how to" on connecting the C-Channel to the shell and subfloor on an airstream? Visuals would be great!!
I have a 73 Argosy.
Kimya W is offline   Reply With Quote
Expansion anchors instead of elevator bolts for shell on floor replacement? timzog Repairing/Replacing Floor &/or Frame 4 12-12-2011 05:43 PM
Replacement issues wander'n Refrigerators 0 10-11-2011 06:25 PM
C channel bolts? Phrunes Repairing/Replacing Floor &/or Frame 11 06-12-2011 09:14 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
