Old 11-10-2015, 06:32 PM   #1
1971 31' Sovereign
Temple , Texas
C-channel break. What to do?
So, I'm replacing the subfloor in the rear of my '71 Sovereign. The last 18" or so was rotted away. I decided to go ahead and replace the entire 4' section. Fortunately, the frame looks pretty good except for surface rust which I will take care of.
You will notice the break in the C-channel at both rear corners. How should I go about repairing this? Thanks, in advance.
Name:	c channel.jpg
ID:	251877   Click image for larger version
TxDave is offline   Reply With Quote
Old 11-10-2015, 08:08 PM   #2
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
I'd say you could solve that a few different ways.
Best way would be to have a sheet metal shop (heating and ac shop) "brake" a new C-Channel, maybe 24" long. Cut out the old / corroded piece, replace w/new. You can splice, simply by placing an 1-1/2" x 6" long piece of aluminum in the base of the C-Channel, spanning 3" on the new and 3" onto the Existing and then screwing it down to the new plywood . . .
You could also just brake a simple "L" shape w/ an 1-1/2" bottom leg and an inch or 2 side leg and "nest" it in over the top of the bad/corroded piece and overlapping some of the good C-Channel and screw to plywood and rivet to the outer skin . . . that's probably what I would do.
Insert Disclaimer Here: I'm just an aluminum hack, not a professional.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 11-10-2015, 08:36 PM   #3
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
First I would check it is indeed a break and not that it is simply a flaw in quality control in that the back and the curves of your C-Channel are sitting not a a parallel. My C-channels had a space but it was on the other edge of the curve. (road and curb side, not at the rear) And its not a flaw, it was made like that. (That is why a lot of leaks appear in the corners of these trailers as the water follows along the channel till it hits these spaces and makes its appearance inside.
First look at that space in the channel and see if it does look stretched and torn or it looks like it could have been cut at the factory with tin snips, then go outside and see what the condition of your rivets are in that area. If your rivet holes are stretched out the corresponding amount and your quarter panel aluminum is buckled inwards than you may have an issue but lets hope its just a simpler issue of bad quality control many moons ago
thesignlady is offline   Reply With Quote
Old 11-10-2015, 10:04 PM   #4
1974 25' Tradewind
Calgary , Alberta
Looks like a stress fracture... and because it's partway around the corners, it will require a compound bend to create the right shape from a flat piece of replacement stock.
It would be possible to create that shape by making a plywood former that fit the inside of the C channel (at least 3/4" ply); then cut out a piece of aluminum that fits the shape, plus an inch on each side to form the vertical sides. Clamp the aluminum to the plywood section by section and hammer-form the sides. With diligence and patience you should be able to recreate the shape of the channel. I would overlap the replacement piece with the existing side pieces by at least three or four inches, and use several rivets per side on each vertical to bridge them together.
Alumineer is offline   Reply With Quote
Old 11-10-2015, 11:30 PM   #5
1971 31' Sovereign
Temple , Texas
Thanks for the great ideas. You guys have me pointed in the right direction.
Thesignlady...I followed your advice and did notice that some of the rivets in that area had pulled through the exterior skin.
MarkR...I have a 10' bending brake. I'm sort of "semi-famous" for a bending brake I designed to build an aluminum airplane completely from scratch. (Google "Dave's bending brake").
Alumineer...that's the same method I used to form wing ribs for my Sonex aircraft. Don't know why I didn't think of this.
Here's a photo of my first aluminum project. I fabricated every piece of this airplane in my garage. 6061 T-6 aluminum with 9,000 rivets.
Old 11-10-2015, 11:57 PM   #6
OilnH2o's Avatar
1976 27' Overlander
Missoula , Montana
TXDave
Nice to know someone else likes "all-aluminum" toys! Nice Sonex, too!
1976 Airstream Overlander International
WBCCI 1054
VAC
TAC
TCT
OilnH2o is offline   Reply With Quote
Old 11-11-2015, 01:30 PM   #7
SpitFireRX's Avatar
1979 31' Excella 500
Florida , Florida
You can also buy one, worked for me
Floor Channel Bow - Narrow Body104463 [104463] - $69.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
SpitFireRX is offline   Reply With Quote
Old 11-11-2015, 02:02 PM   #8
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
I'm surprised you had to ask anyone anything if you built a plane...LOL!
twolanehwy is offline   Reply With Quote
Old 11-11-2015, 11:44 PM   #9
1971 31' Sovereign
Temple , Texas
OilnH2o...that's a sweet Bonanza.
SpitFireRX...do you remember how much you paid for shipping. Their website says it ships freight.
twolanehwy...one important lesson I learned while building my Sonex was to take advantage of other folks knowledge and experience. Its that old "2 heads are better than one" thing. I am a total Airstream newbie. But, if you ever need any advice on building an airplane from scratch...I'm your man.
Old 11-12-2015, 07:55 AM   #10
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I don't own it though. I have built a Pitts S2B and a Harmon Rocket.
Old 11-13-2015, 10:52 AM   #11
SpitFireRX's Avatar
Florida , Florida
TxDave
total freight $134.17 but i also purchased a Channel Floor Molding 16ft Piece 100986 that i had cut in half for me.
Old 11-13-2015, 11:29 AM   #12
mapleton , Utah
I have to second Alumineer on the stress fracture diagnosis. It seems too coincidental that both sides broke at the frame ends. Was the floor badly rotted in this area? if so the unsupported shell probably flexed excessively relative to the frame. Adding a front hold down plate to keep the shell more rigidly attached at the A frame might be a good idea to help avoid a repeat.
tim
rumrunner is offline   Reply With Quote
Old 11-13-2015, 08:48 PM   #13
1971 31' Sovereign
Temple , Texas
Yes, rumrunner, the last 18" or so of the plywood subfloor was pretty much toast. I think your explanation makes sense. Thanks.
Old 11-14-2015, 09:28 AM   #14
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
I'm just about to have some channel formed up. What alloy do you think would be best?
I've seen just about every alloy used on this forum.
I was gonna use 5052. What do you think would have best characteristics for bending and not cracking after being bent?
C channel/U channel replacement cole3444 Repairing/Replacing Floor &/or Frame 10 01-31-2014 08:50 PM
Break-away cable broke... crazylev On The Road... 9 08-16-2004 07:24 PM
Break Control luckydc Brakes & Brake Controllers 6 02-22-2004 07:27 PM
What am I going to break next? drboyd General Repair Forum 0 09-22-2003 12:47 PM
Break Away Brake Switch davespann Brakes & Brake Controllers 1 07-30-2003 09:22 PM
