05-22-2014, 06:33 PM
1971 27' Overlander
Dickinson
, North Dakota
C channel advice in 1971 Overlander restoration.
I had some pieces of aluminum bent up to replace the rear c channel on my overlander that was broken off at the two frame attachment points. No one around here had aluminum longer than 4 feet so that is what I ended up with. So as you can see in the photos there is the piece I need to replace and the pieces I have to use to replace it with. I had them make the legs a bit longer to give a little more to mount too. I also had them make up a new stainless hold down plate as well. What would be the best way to transition from the old channel to the new? Also, is there any other practical way to make the curved bits than cutting slots and trying to re-create the original radius? Thanks!
05-24-2014, 02:12 PM
1971 27' Overlander
Dickinson
, North Dakota
Hmm... Must be a stumper of a question!
05-24-2014, 03:45 PM
Portsmouth
, Virginia
Anything is possible, but that is probably beyond what most folks can do. The c channel just has to connect the ribs down to the floor, it doesnt have to be really pretty. As for the transition, they may have welded them originally, but probably the best you can do is over lap it some with a bolt in the middle to hold it together.
05-27-2014, 04:19 PM
1971 27' Overlander
Dickinson
, North Dakota
Thanks for the reply Bob! I think what I'll end up doing is taking it to the chop saw and marking about 1" marks along the radius. I'm hoping that will allow enough of a bent to make the corner. Since I have to use two pieces to eventually replace the one continuous piece that is in there, I'll make the splice in the center of the trailer and that way it will have the rear hold down plate to reinforce the splice. On the outer ends I'll try and get it under the old C channel and see if I can run it under about 6 inches and get one or two elevator bolts in there.
I'll try and update this thread as I progress for future reference.
05-27-2014, 05:48 PM
1966 17' Caravel
Newport
, North Carolina
I know that mine is a different year but I had the c channel made a little higher and then ended up cutting most of it back to get it to fit.!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
05-27-2014, 05:57 PM
1971 27' Overlander
Dickinson
, North Dakota
Cliff. I had the same thought and tried to measure things out multiple times. However, as it seems with all projects so far there will certainly be some snafu to create a few more hours of time and labor!!
Thanks for the reply!
06-11-2014, 09:59 AM
1963 22' Safari
Vail
Ryan
I am thinking doing something similar. Will probably buy some commercially available "u" channel. To make the curved section, I am thinking of slitting the channel periodically to approximate the original "curved" section. I will put a flat piece of metal in the bottom (cut to fit the arc) and bolt that to the floor; I think that will give it near the original strength. I think a flat piece of metal that will fit the bottom of the channel would be a good way to make a strong joint where to piece butt together.
Best wishes for your success; let us know how it goes.
Owen Bennett (aka Morganobenn)
06-11-2014, 10:20 AM
1971 27' Overlander
Dickinson
, North Dakota
06-12-2014, 09:54 AM
1963 22' Safari
Vail
Ryan
Thanks for the photos. I agree that this approach is stronger. Good luck in closing out.
Owen
06-16-2014, 10:49 AM
1972 27' Overlander
Denver
, North Carolina
If you ever get a chance to see a 50s Airstream opened up, you will see the C channel is many different pieces.
Lucky Dave, Denver NC
06-16-2014, 11:17 AM
1981 31' Excella II
New Market
, Alabama
That should work. I did something similar on mine.
Perry
06-16-2014, 11:54 AM
1971 27' Overlander
Jackson
, Tennessee
Nice work - and much stronger than original.
Alan
