Old 08-14-2011, 08:41 PM   #1
1964 26' Overlander
Renton , Washington
C-Channel?
I'm finally getting around to fixing the rotted floor on the front curb-side of my 64 Overlander. I've read a lot of posts and it's my understanding that there is a C-channel that runs around the frame and that the floor slips into the C-channel and is then bolted through the c-channel and the subfloor.
I've removed part of the rotted floor and I cannot find a C-channel, not at the curve, which sags even though not rotted, nor along the side where there is rot. It appears as if the floor was just on top of the frame and under the wall.
Am I misunderstanding how the floor was laid?
If there is supposed to be a c-channel and there is none, what do I do?
Thanks.
deb
dejahardy13 is offline   Reply With Quote
Old 08-14-2011, 10:07 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I'm refurbishing a 1964 Bambi II. The "c-channel" wasn't a c-channel in mine either. It was more like a u-channel. The channel is bolted directly to the floor--it doesn't slip in the channel. The skins are riveted to the rear of the channel, which sits up higher than the inside (front) of the channel. Make sense? If not, I can get a picture of what my channel looks like. I had new channel fabricated at a local shop. If you don't need a lot, you can bend it yourself. Mine was completely trashed. The c-channel was in newer models than ours.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-15-2011, 10:26 PM   #3
1964 26' Overlander
Renton , Washington
C-channels and U-channels
Thank you.
A picture would be very helpful. I think I'm seeing what you are describing, but my trailer doesn't seem to have that, either. All I can see is the metal beam that crosses the trailer and the metal beam that the wall is attached to.
Maybe I should post a picture, too.
Old 08-16-2011, 12:00 AM   #4
Tool Hoarder
West , California
Usually the 60's trailers have U channel that is bolted thru the floor. i made mine out of 3003 .032 Al and a 36" metal break, super easy.
marzboy is offline   Reply With Quote
Old 08-16-2011, 06:35 AM   #5
Becky B.'s Avatar
1964 17' Bambi II
Yep, that's what mine has too.
Becky
1964 Bambi II
1988 Avion 32S
Old 08-16-2011, 08:38 PM   #6
flygrrl
flygrrl's Avatar
1962 19' Globetrotter
Winchester , Ontario
Pictures please
Hi Deb, yup, a pic of what you have would be very helpful so we can all diagnose your dilemma.
Leonie
Originally Posted by dejahardy13 View Post
Thank you.
TV: 2007 Jeep GC Laredo diesel
Toy: 1995 Jeep YJ
Experience is what you get from not having it when you needed it.
flygrrl is offline   Reply With Quote
Old 08-17-2011, 09:28 PM   #7
1964 26' Overlander
Renton , Washington
Where's the c-channel?
This is the view through the hole in the rotted floor. I can't find any kind of channel.
This is the floor forward of the hole. The wood isn't rotted, but it sinks half an inch if you step on it, as if nothing is holding it up.
The wall is in the way of seeing what might be above, but wouldn't the channel be at the same level as the beam that crosses the trailer?
All help gratefully accepted.
Old 08-17-2011, 10:11 PM   #8
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
<img src="http://www.airforums.com/forums/attachment.php?attachmentid=138001"/>
<img src="http://www.airforums.com/forums/attachment.php?attachmentid=138002"/>
Yours may have done what mine did. After prolonged exposure to moisture and the chemicals present in plywood (lye specifically) the aluminum begins a chemical process and breaks down. Over time it can separate from itself and may have just fallen out? A section of mine was hanging on by just one 1/8" sliver. Here are some pics of the afflicted area that fell out.
ID:	138008   Click image for larger version
Phrunes is offline   Reply With Quote
Old 08-17-2011, 10:32 PM   #9
LawChick's Avatar
1992 29' Excella
1987 32' Excella
Morrilton , Arkansas
Images: 55
Your missing c-channel
I posted under your photo, but I probably misspoke. I thought the trailer was closer to the age of mine, 1992. I have no idea what is in a vintage trailer like yours. Better ask the vintage folks. You may have something entirely different. That's what I get for opening my mouth before I looked closer to see what kind of trailer you actually have! Sorry.
Carol
2004 Dodge Ram 2500 Cummins HD
1987 Excella 32'
"Besides, I'm a gypsy at heart
and I like to travel around."
Reba McEntire
LawChick is offline   Reply With Quote
Old 08-18-2011, 04:59 AM   #10
Baltimore , Maryland
Okay, I think it important you learn and understand Airstream construction before you take on what is a very serious(but not too hard) repair.
To actually see the "c" channel you need to remove that interior skin. The channel is the filling in a wall sandwich. It is bolted to the floor and also into the outriggers. Drill off the interior skin and you will clearly see your "c" channel is in place.
To Phrunes, I have never heard of lye in plywood. Is it also the mouse urine? Because it is mouse urine that eats aluminum channel in most cases. Nasty fact, but true.
Old 08-18-2011, 08:20 AM   #11
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Anothe strange one but yes, wet decomposing wood creates lye. That mouse urine fact is just disgustin! Haha
Old 08-19-2011, 11:35 PM   #12
1964 26' Overlander
Renton , Washington
Ooooooooooooooo
Not hard? Oooooookay.
I don't really understand why I can't see it since the wood is not there anymore, but I do understand the concept and have read that it is best to drop the belly skin to replace the floor.
I'm not sure if I have the original interior skin. Is it supposed to be a type of composition board?
Is the channel aluminum or steel? Mouse urine. Plywood lye. Wow!
Thanks, everyone. You're giving me a great education!
Old 08-20-2011, 07:08 AM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The interior skin is aluminum sheet, with a Zolatone finish. The floor channel is aluminum.
Old 08-20-2011, 09:57 PM   #14
1964 26' Overlander
Renton , Washington
Misconceptions
Thank you, 62Overlander (Terri?). You have corrected several of my misconceptions. I had thought the c-channel was steel. I had also thought that there was a steel beam on each side of the chassis. I completely misunderstood about the outriggers. Up until now, the pictures I had seen of the floor still had the shell on. After getting your post, I went looking for more pictures of just the chassis. Wow! How wrong can you be?
Marzboy, how does a U-channel work? I'm having trouble wrapping my mind around it. It looks like the floor would be held up by just the edge of the lower side of the U.
Does anyone know of a book that discusses how Airstreams are built and how to use and fix one?
Thanks again, all. I would love more information about how to go about this fairly cheaply by a complete novice. :-)
deb
c-channel, floor, rotten
C channel bolts? Phrunes Repairing/Replacing Floor &/or Frame 11 06-12-2011 09:14 PM
Tempro/Vulkem under c channel? Becky B. Repairing/Replacing Floor &/or Frame 2 05-23-2011 05:43 AM
C Channel tracker Repairing/Replacing Floor &/or Frame 5 05-04-2011 05:18 PM
Floor channel size when installing 3/4" plywood? surfpod Repairing/Replacing Floor &/or Frame 8 05-03-2011 12:25 PM
Looking to Rent a Airstream Bambi For The Science Channel! Kylebkr Forum Admin, News and Member Account Info 1 03-31-2011 05:28 PM
