Old 08-19-2011, 08:57 PM   #1
1976 31' Sovereign
Pittsburgh , Pennsylvania
C Channel 1976 Sovereign
Hello all,
I am in the process of removing some rotter subfloor but I can't seem to figure out the C Channel. I have removed the wall panels but it isn't as sell explanatory as I imagined. Is the plywood sandwiched in or bolted? It looks like the sheets should slide in but I also noticed some long rusty and bent bolts.
Any ideas?
Thanks!
Mikal
gronlampa is offline   Reply With Quote
Old 08-19-2011, 09:52 PM   #2
1975 31' Sovereign
Brownsville , Texas
Since my 75 needs the floor replaced in the bathroom, I'm waiting to see if you get any replies. I posted to see If I can keep this bumped up the list.
rkuhns956 is offline   Reply With Quote
Old 08-19-2011, 10:08 PM   #3
x
XXXX , XXXX
Originally Posted by gronlampa View Post
Hello all,
Any ideas?
Thanks!
Mikal
To answer your question it's both sandwiched in and bolted down. For the end caps of the trailer the C channel is sitting on top of the floor and bolted down through the floor into the outriggers along the sides of the end caps. Across the front section of the front end cap there are two large bolts through the c channel, floor and into the main frame rails. Along the rear of the rear end cap ther are two more large bolts through the c channel, floor and into the main frame rails.
Along the sides of the trailer the c channel is actually a double c. One c is vertical and the shell and the interior skins(walls) are riveted to that part. The second c is horizontal and the floor sheets are inserted into that part and then bolted down through both parts of the c channel, floor and into the outriggers for the frame.
I've attached a couple of pictures of a small piece of the double c channel.
Name:	C channel 001.jpg
ID:	138188   Click image for larger version
Name:	C channel 002.jpg
wasagachris is offline   Reply With Quote
Old 08-23-2011, 10:56 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Double C channels
Wasagachris,
So if a guy was trying to replace his entire floor without removing the shell completely, is it feasible to slide the full width floor sections into the double C channels along the sides without splitting them down the middle? Also, I was surprised to see that my floor thickness (1973 Globetrotter) seems to be 3/4" from the factory. I was under the impression I should expect it to be 5/8"
Old 08-23-2011, 11:07 AM   #5
x
XXXX , XXXX
Originally Posted by Belegedhel View Post
Wasagachris,
No it is not. The fit is quite tight into the channel it wouldn't slide in at all. Also you can't cut the sheets of floor in half down the middle as there will be no support under the seam. It would need to be cut so that the seam is on top of the main frame rails and I would offset the cuts. IE: first sheet curbside, next sheet roadside etc.
How many sheets for flooring is in your GT? The front and back sheets actually have the shell sitting on top of the floor and don't have the double c channel.
I have seen where someone spread the shell apart and used a full sheet of flooring but he needed to build a turnbuckle clamp system to pull the shell back into the double c channel. He almost had a bad mishap where the shell almost fell down over the frame when it slipped off the outriggers.
Old 08-23-2011, 11:39 AM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Someone? That was me. I didn't really think of it as a bad mishap (it slipped off just one outrigger, but the plywood was already holding the shell up). It was just something to watch for and be more careful of. At the risk of opening a religious discussion, we did a shell on total floor replacement, and I say it can be done. It all comes down to your comfort level. You certainly have to be more careful doing a shell on floor replacement. If we had it to do over again, we might do a shell off. But, I don't think we'll ever be a position to find out, at least not until we get this one on the road!
There are many threads where people have done a shell off, including Wasaga Chris' thread. There are fewer threads of people doing a shell on, but I know of at least two (one of them is our 72' Sovereign Little Girl Refurb thread).
Btw - the turnbuckle clamp thing is available to anyone that wants it. I have no idea what I'm going to do with it now.
Chris
Old 08-23-2011, 11:58 AM   #7
x
XXXX , XXXX
Hey MC I did say ALMOST.
With a GT being that it is so small you probably could do a half and half floor replacement like TOP did for his Sovereign. Replace the rear two or three sheets then move up front and replace the other two sheets.
I just think that it's not that hard to pull the shell and once off it makes the rest of the work easier to do.
I was hesitatnt as heck to do the shell off but once I got into it it was fairly easy. I was quite surprised how well the shell dropped back down on the new frame/floor combo.
Old 08-23-2011, 01:55 PM   #8
Belegedhel's Avatar
Houston , Texas
So to do a shell off floor replacement on these '70s era trailers with the double C channels, would you drill out the rivets holding the shell to the double C channels, lift the shell, then remove the channels from the plywood, replace the plywood, replace the channels, and then drop the shell, re-rivet, and re-bolt?
Old 08-23-2011, 02:52 PM   #9
x
XXXX , XXXX
Got it in one. The single channel around the end caps can stay attached to the shell but that's exactly how to take them apart. First the lower beltline trim that is attached with pop rivets needs to come off. Then the side wraps and banana wraps for the belly pan come off. Then it's just like you described. I took all the belly pan out first but you can take out the flat section after the shell is off. You need all the belly off to replace the floor for access to the elevator bolts during the install of the new floor.
Old 08-23-2011, 03:47 PM   #10
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
I'm wondering the same thing.
Thanks for asking, because I was wondering the same thing. I haven't removed my interior skins (1974 Overlander) yet to actually see the infamous "C" channel.
2Rhinos is offline   Reply With Quote
Old 08-23-2011, 10:27 PM   #11
1976 31' Sovereign
If I already need to fix a good many leaks and I will also be removing the interior skin, what stops me from breaking down the Airstream outer skin, rebuilding the floor and frame, then re-riveting the entire thing?
I plan to replace all wiring etc. as well.
Is lifting the shell an reasonable task? I would need to do the work in my field so I am concerned about wind etc.
Is there a Hanyne's style book for Airstream?
Thanks!
Mikal
Old 08-24-2011, 02:27 AM   #12
x
XXXX , XXXX
Mikal The first question that I would ask you is why do you want to `break down the outer skin`. The shell can be removed without removing any of the outer panels. Actually the strength of the shell is from having the inner skins and outer panels attached to the ribs, if both the inner skins and the outer panels were removed the shell structure would be subject to twisting and bending.
Lifting the shell is quite easy to do. Most of the pros have built a gantry setup to lift the shell from above through the roof vents. I lifted it using two small bottle jacks placed on the floor of the trailer, lifting against the cribbing I attached to the shell to keep it straight while off the chassis. The cribbing was made with 2x6 attached between the ribs of the shell.
Yes of course wind is a concern. You will need to secure the shell to the ground to keep it from lifting up or toppling over after it has been removed from the chassis.
Here you can see the cribbing and also if you look in the lower left of the shot you can see one of the bottle jacks I used.
Name:	Shell Removal 006.jpg
Airstream sells service manuals as well as owners manuals for your year of trailer.
https://store.airstream.com/product_...products_id=96
https://store.airstream.com/product_...roducts_id=384
Old 08-24-2011, 07:24 PM   #13
1976 31' Sovereign
To answer your question, I don't want to dismantle the shell but I figured since I have to remove so many panels, repair windows, replace fans, and replace y air conditioner that I might not be far from doing so.
Not sure what a gantry is but I image it is similar to a engine hoist?
If I did decide to life it, how long could I leave it off without running the risk of damaging it?
How long did it take you to repair your frame and replace your subfloor? Could it be a weekend project?
Should I replace the axles at the same time?
Is there a suggested path to restoration (i.e. Frame then subfloor then wiring?
I want to make sure I am repairing things in the proper order so I don't end up doing the same job twice.
Thanks!
Mikal
Old 08-24-2011, 07:40 PM   #14
x
XXXX , XXXX
Mikal as long as the shell is properly supported it can remain off the chassis for quite some time.
It took me ten weeks to lift the shell, build the frame, attach the new floor and axles etc and get the shell back on. I tried to work on it every day but sometimes work and the weather got in the way. I don't think you can do it in a weekend. It all depends how much frame /floor repair you need to do. Right now I'm about half way through the polishing stage then I will be installing awnings, sat dish and solar panels. then the shell gets sealed and I move on to the inside.
Yes I would replace the axles at the same time it's much easier to do then.
If I had it to do over again I would fix the shell, leaks, seals, panel replacement first before pulling the shell. That way once you do the frame and floor and the shell goes back on it's sealed up and you don't risk damaging the new floor from any leaks. Once the shell is back on and the belly is insulated and installed then move inside to insulation, wiring, plumbing, reinstall the inner skins. Then the bulkheads and furniture, appliances can be installed. Some things will overlap like part of the plumbing and wiring must be done along with shell and belly replacement and some of it won't be finished until the furniture, bulkheads and appliances go back in.
sovereign
1976 Airstream Sovereign adonh Airstream Registry Discussions 1 10-24-2011 02:18 PM
Airstream land yacht sovereign international 1976 eBay Watch Airstreams on eBay 0 05-07-2011 05:00 PM
1976 Airstream Sovereign International Land Yacht 31 ft eBay Watch Airstreams on eBay 0 04-24-2011 06:40 PM
1976 Airstream Sovereign International Land Yacht 31 ft eBay Watch Airstreams on eBay 0 04-16-2011 04:10 PM
1976 Sovereign Restoration socko12345 General Interior Topics 12 04-15-2011 11:46 AM
