Old 05-11-2016, 07:44 PM   #1
1975 31' Sovereign
Minneapolis , Minnesota
Bolts or Screws in 1975 Sovereign
I just completed a "shell on" subfloor replacement in my 1975 Sovereign. I tore out all of the old, rotted subfloor by cutting the bolts in the C-channel, reinsulated and replace the subfloor with 3/4" new plywood. I was able to complete this with the belly pan on. However, I now need to secure the shell to the chassis.
Is there anyway to attach the frame to the chassis through the subfloor without removing the belly pan? Is it possible to use self tapping screws through the C-channel and into the chassis in order to avoid needing a bolt or is this far too dangerous? Any insight would be appreciated.
kvsterner is offline   Reply With Quote
Old 05-11-2016, 08:02 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
IMHO 1/4" self tappers will work fine if you miss the existing holes.
There will be people who will disagree with me about that though.
Superat stultitia.
Old 05-11-2016, 08:29 PM   #3
Mixter's Avatar
1976 27' Overlander
Hmmm.... I dont know. Thats a fairly important fastening point to the monocoque design... I personally might consider that in a pinch for a few places because you replaced sections of the subfloor, but for the whole thing I'd be leary.
On the '75, you might be able to leave the rubrail on, and just drill out the rivets underneath the outriggers and along the main frame rail to pull them free enough to get at the underside of a bolt/nut fastener.
The rubrail removal to do it is definitely alot of work. I think I could get to mine leaving the rubrail alone.
Mixter is offline   Reply With Quote
Old 05-12-2016, 06:15 PM   #4
1975 31' Sovereign
Thank you both. This is helpful!
sovereign
Bolts and Screws to attach the subfloor Nezstaffani Repairing/Replacing Floor &/or Frame 1 03-14-2016 09:00 PM
Finding floor bolts/screws without removing vinyl flooring Brasslens Repairing/Replacing Floor &/or Frame 6 01-05-2015 10:30 AM
lower Hot water cover screws, bolts ? Bob Sheridan Vintage Kin 2 10-12-2011 12:21 PM
Help with removal of rusty Bolts/Screws KATYBELLE Repairing/Replacing Floor &/or Frame 11 02-09-2011 08:26 AM
Where to put j bolts, screws and adhesive JoePfznik Repairing/Replacing Floor &/or Frame 1 12-17-2009 07:29 AM
