Originally Posted by wahoonc
OUCH! I am not an engineer (and I sometimes question if Airstream has any on payroll) but I cannot see how you could eliminate that plate and still have a durable system...but that is my opinion.Aaron
hi aaron
attached are photos showing what's typical of front end skeletons on modern units....
no plate. there are bolts attaching the floor channel to the frame...
the short vertical aluminum stays at the front have replaced the plate...
of course these are only riveted to the floor channel, NOT attached to the frame...
the 2 pix show 'with' a front hatch and without...
the last pix shows a wider view of the full insides...
and makes it clear 'semi monoque' is a thing of the past...
it is easy to see where the wall sections, roof section and end cap section are tacked together...
so newer units really do rely on the frame/floor for structural integrity...
i'm not sure frame construction has kept up with the new load demands.
of course they
claim these segmentally assembled units are stronger than the one piece rib and higher rivet counts skins...
Originally Posted by Pick
... Those that think they can build a perfect Airstream should ...
no one has suggested perfection is the benchmark,
but units have gotten heavier and wider until this new interest in little/lite
and gradually removing key elements of construction while shortening the warranty...
isn't suggestive of company trust in the design, materials OR construction.
this year a/s considered SHORTENING the warranty to
ONE year....
rebuilds, repairs, leaks, and repeat fixes of the same problems are killing their bottom line...
the good news is buyers don't need to wait 20 or 30 years for front end separation to appear....
the service center is seeing this issue in nearly NEW units and back into the 90s (like howieE)...
the fact is most a/s trailers and owners travel very little....
they sit in the yard or storage lot or roll to the lake an hour away...
but folks who put on miles or take long long trips should all be aware.
real travelers are the ultimate laboratory and the mouse is falling apart!
front end separation IS the new rear end issue revisited... and beatrice isn't too blame.
cheers
2air'
i posted these pix in fairly high resolution so you will need to open them in a new window and zoom some...
