Old 09-18-2007, 10:15 PM   #1
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Images: 65
It's a small world after all.
Dave,
How ya like it!
Michael
Click here Airstream Posters & Tee's
by Micheal Joseph Depraida
WBCCI No 8892 | VAC | KC2TQU
ArtStream is offline   Reply With Quote
Old 09-18-2007, 10:26 PM   #2
munimula's Avatar
Profile:  1993 34' Excella
1964 24' Tradewind
Rockaway , New Jersey
Originally Posted by Artstream
Dave,
How ya like it!
Michael
LOVE IT! I'll be wearing it this weekend at the NJ State Rally. next i want a print to add to my Airstream art collection that hangs in my Airstream room.
--dave
munimula is offline   Reply With Quote
Old 09-11-2007, 06:34 PM   #3
DFord79's Avatar
Profile:  Currently Looking...
Yakima , Washington
Red face
I haul things and need the 3/4 ton. If I go camping or a long trip I like to take things with me so I am self supportive. I would be overloaded with a half ton and a bed full of generator and tools....and camping stuff with a Gorrila slide and Bed cover that weight almost 500# without anything in them. Thats why I was asking about the 3/4 ton. I go prepared for anything....I am the one who usually is ask to help out when others are in trouble. I have always been that way and always will be. I take tools and a 250lb genny....But its quiet..lol...HONDA Eu6500i....its almost as quiet as the 2000i...but I need the load capacity. A half ton won't do it. Thank Andy..you answer my question. I talk too much...lol
DFord79 is offline   Reply With Quote
Old 09-11-2007, 06:58 PM   #4
StingrayL82's Avatar
Profile:  1971 31' Sovereign
San Angelo , Texas
Images: 37
DFord79,
As it stands right now, based on the research I've done, the only 1/2 ton truck which stands half a chance of towing a 34'r is the Ford F-150, because it has a fully boxed frame. That said, even with a 10,000lb tow rating, I still wouldn't use a 1/2 ton to tow that much weight.
My 2005 Dodge Ram 3/4 ton CTD was rated to tow 13,000lbs. My 2001 Dodge Ram 1 ton CTD is rated to 14,300lbs. You only want to tow about 80% of the vehicle's maximum tow rating.
Towing a 34'r with a 1/2 ton is just plain dangerous and can get someone seriously injured/killed. When towing, make sure your vehicle is properly equipped, ie: proper brake controller, proper sized tow vehicle brakes (most manufacturers have tow packages), jake brake for insurance, if you're towing a decent sized trailer.
Hope that helps with your decision.
Frederic
SFC Frederic Lynes
1971 Sovereign International
2004 F-350 King Ranch
EX-WBCCI # 8371
AIR # 8239
StingrayL82 is offline   Reply With Quote
Old 09-11-2007, 07:13 PM   #5
DFord79's Avatar
Yakima , Washington
Originally Posted by StingrayL82
DFord79,
Frederic
I agree completely with Bigger is better when towing for safety sake. I am a fleet manager and understand pickup truck capabilities. I was just worried about this separation thing with the AS. I would tow with a ONE TON dually if it would not tear up the AS. I carry stuff....So I need more truck. MORE brakes....is a biggie too. The 80% rule is a good thing to go buy with regards to safety.
Old 09-11-2007, 07:39 PM   #6
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Duallies are a no-no for towing Airstreams, unless it is one of the 5th wheel models. With twice as many tires in the back to run over bumps in the road, and a very stiff suspension, they will eat your trailer's lunch in short order. BTW, my 3/4 ton pickup has 2000 pound payload. I'm not sure when 3/4 ton stopped equalling 1500 pounds. Even with that, towing capacity is still 8500 pounds.
(No Longer at Inland RV)
Old 09-11-2007, 06:00 PM   #7
DFord79's Avatar
Yakima , Washington
I ask this because We are making plans to buy a new tow vehicle in the not too far distant future. I was thinking of a 3/4 ton to pull a 25' Safari. And...We haul a bunch of stuff in the bed with a heavy canopy and tool boxes also?
Old 09-12-2007, 05:20 PM   #8
Airstreamer67's Avatar
Profile:
2Air, you are telling it like it is.
My solution was to buy a Class V AirSafe air hitch. It delivers everything the manufacturer promises, and allows the use of my weight transfer bars. With this hitch, my 3/4 ton truck's harsh suspension is effectively isolated from the trailer's. Each gyrate independently over the potholes and railroad tracks of today's highways. For me, it is the answer to the dilemma you write so insightfully about.
Airstreamer67 is offline   Reply With Quote
Old 09-12-2007, 05:35 PM   #9
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
As the repair continues I may have lucked out a bit better than some. There was no indication the floor had seperated from the frame, all floor bolts were in tact. I did however remove the 2 that were between the battery boxes in order to mount a 1 1/4 in Al. angle to replace the standing web of the floor channel, torn off during the deterioration. This angle is now held down by 4 new bolts and an additionial flat strip of Al. to act as a large flange under the bolts.
The attached picture shows the angle in place before the bolts were set. I used under belly revits through the outer skin and into the angle because the larger diameter would offer additional bearing area against future failure.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
HowieE is online now   Reply With Quote
Old 09-12-2007, 05:48 PM   #10
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Artist , at Large
Images: 65
Lookin good HowieE.
As mentioned by others I also have a ClassV Airhitch.
Put 40,000 on it after I did a front end repair. The front end is still tight.
700 lb bars, E350 7.3l td, dually.
Michael
2Air, you rock !
Old 10-02-2007, 11:35 PM   #11
Profile:  2007 25' Safari SS SE
Alton , Illinois
Is that front hold down plate a cure-all? I thought AS was using heavier panels? Is this problem more likely to occur in heavier (Classic) or longer 31-34 footers? Just curious. What can be done to prevent? How expensive would it be for AS to build the fix right into the trailer (might be naive here). Would sure make me sick--best of luck
The "Ann Rutledge"
Brad Hunt is offline   Reply With Quote
Old 10-03-2007, 05:32 AM   #12
Commercial Vendor
Profile:  Corona , California
That problem can occur on any size Airstream.
It's usual cause, is from vibration.
That vibration can be a combination of super duty tow vehicle, using excessively rated hitch bars, along with lack of proper running gear balance.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 10-03-2007, 09:50 AM   #13
dmreilly10000's Avatar
Profile:  1953 25' Cruiser
Brandon (near reservoir) , Mississippi
Images: 14
The world has changed since the 1950's and 1960's and 3/4 and 1 ton diesel trucks are the norm today. Wouldn't it be nice if Airstream would re-engineer their trailers to be able to take the strain? I imagine all of the other SOBs have.
We don't tow with cars and station waggons anymore. (except at Can-AM RV in Canada Welcome to Can-Am RV Centre: I particurly like the Jag and the little Mercedes towing a 34 footer) Because of weight restrictions and safety concerns, we don't use 1/2 ton trucks to tow with anymore. We don't travel on the old non-interstate highways for the most part anymore. If I paid $40 to $90 thousand dollars for a new Airstream and it promptly proceded to rip apart, I would be very disapointed.
On the subject of the 34 foot Airstreams, I would like to know what other truck other than a "heavy duty" could pull the thing adequately and safely? I tried to pull mine with a 3/4 ton long wheelbase Chevy with a 350 gas engine and it wasn't up to the task (the truck chasis was, though).
AIRSTREAM - modify your trailers so that they can be towed with modern trucks.
dmreilly10000 is offline   Reply With Quote
Old 10-03-2007, 10:08 AM   #14
munimula's Avatar
1964 24' Tradewind
I know of a guy in the NY Metro Unit who pulled his 34 footer to Alaska and back with a Safari minivan. The Safari is still his tow vehicle.
--dave
Tail sag and separation Dan Phariss Repairing/Replacing Floor &/or Frame 111 10-27-2009 04:33 PM
Rear End Sag Not Separation airstream74 Repairing/Replacing Floor &/or Frame 44 12-27-2006 10:31 PM
Narrow body/Wide body jcanavera Our Community 11 04-05-2006 02:25 PM
Rear End Separation 76argosy26 Repairing/Replacing Floor &/or Frame 6 09-13-2004 10:32 PM
Ed & Debbie want separation RivetED Our Community 11 01-29-2004 06:40 AM
