Old 02-03-2014, 09:02 PM   #15
Mixter's Avatar
1976 27' Overlander
Oops! And here is the link:
http://www.airforums.com/forums/f36/...ns-104015.html
Mixter is offline   Reply With Quote
Old 02-04-2014, 02:51 AM   #16
Baltimore , Maryland
Your shell weights about 400 pounds. It does not take a heavy set up as many think. Most people over brace with tons of wood weighing more than the shell does. I do not even brace when I lift using my gantry.
Old 04-07-2014, 05:33 PM   #17
JCPOTTERF's Avatar
1963 28' Ambassador
Danielsville , Georgia
I've made one of two gantries it's in place. Thanks for the help! One more to build and lift off hopefully this weekend .
working through life: Photo
JCPOTTERF is offline   Reply With Quote
Old 05-10-2014, 07:54 AM   #18
1963 19' Globetrotter
How did you secure your 2x4 ladder framing to the rails of the airstream. Curious how your going to take it off the jacks and move it. I'm about to do the same. I heard its also best to keep the inner skins on as it makes the structure more rigid but I removed mine already. Fun project.
Tonianne is offline   Reply With Quote
Old 05-10-2014, 07:56 AM   #19
Is it best to leave the inner skins on before the lift? I heard it makes it more rigid.
Old 05-10-2014, 08:44 AM   #20
Mixter's Avatar
1976 27' Overlander
There is absolutely no need to "reinforce" the shell with any framing. Reinforcement will just make it heavier. Same for the inside skins. The shell is very strong when you lift it off.
Old 05-12-2014, 08:41 PM   #21
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There seems to be a common belief that the inner skins are a critical part of the shell structure. They may contribute something to the system, but when you compare the relate sparcity of the POP-RIVETS holding them in place to the BUCKED rivets every inch or so in the outer shell, you may come to the conclusion that the support provided is minimal. If the inner skins are structural, then so is the belt line trim and the cabinets.
I lifted my shell without inner skins and zero additional bracing, and I have been going camping without the inner skins in place and a nice heavy AC on the roof. No issues.
Old 05-18-2014, 07:31 AM   #22
JCPOTTERF's Avatar
1963 28' Ambassador
body lift
I used deck screws through the ribs to install 2x4 s for bracing. After the shell was off I drove the trailer out lowered the body just touching the grass and staked in 2x4s on all of the braces its been ok so far.
Old 05-18-2014, 06:39 PM   #23
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
I'm with you on brace and stake. Taking no chances on wind rolling her down the valley like a beer can.
putback is offline   Reply With Quote
Old 05-19-2014, 04:50 AM   #24
do yourself a favor, before you drop it back down, remove the bracing. It makes getting the shell back where it needs to be much easier.
Old 06-26-2014, 12:05 AM   #25
1972 27' Overlander
Loomis , California
thanks for the gantry link!
digidad is offline   Reply With Quote
Old 12-14-2014, 11:06 AM   #26
GlamperGirl
ok so No need for crazy bracing Frank? I am looking at all these posts in the Search Results. The complexity looks crazy. About to do the 65 Globetrotter.
thumbelinadj is offline   Reply With Quote
Old 12-14-2014, 03:32 PM   #27
I do not brace. Many do however.
Old 12-19-2014, 02:08 PM   #28
No bracing except a beam down the center. These photos are from this morning.
Something always snags and puts the shell off center during the lift. It is no big deal when lowering it back down.
Newbie Question Kd9 2011 - 2015 International 57 09-14-2015 07:08 PM
Shell lift off question sawdawg1 Repairing/Replacing Floor &/or Frame 6 01-29-2012 07:03 PM
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
EVAP Canister? question 8rmesse Classic Motorhomes 23 04-24-2011 06:41 AM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
