Old 04-16-2014, 08:52 PM   #1
merrypaws's Avatar
1976 25' Tradewind
xxxx , Delaware
Blind bolts?
Has anyone ever used these blind bolts for attaching the c-channel to the frame when replacing the floor (when you cannot/prefer not to drop the belly pan)?
Abrafast | Blind Bolt
Blind Bolt Technical Information
Functionally this is ideal. But I don't have the engineering knowledge to know if the tensile and shear strengths are sufficient for the towing movements. But the website shows their applications to be pretty hefty steel construction...
Would have to use the 3/8 bolt to get the right fixing depth... $3 each... $25 min... Not too bad...
merrypaws is offline   Reply With Quote
just bought a 61 globetrotter blind & nekkid greenrig Member Introductions 7 03-21-2008 10:10 AM
Venetian Blind material GJ Excella Upholstery, Blinds, Walls & Interior Finishes 4 01-01-2008 06:04 PM
woven wood blind in living room MH 310 1984 JanP Upholstery, Blinds, Walls & Interior Finishes 14 10-14-2006 08:57 PM
Blind floor bolt option? malconium Repairing/Replacing Floor &/or Frame 16 11-17-2004 01:11 AM
