Old 07-15-2015, 11:12 AM   #1
1960 22' Safari
Johnson City , Tennessee
Black water Tank as floor template
I noticed my rear bath black water tank has a parallel curve with the walls, since my original subfloor disintegrated, what are the chances the black water tank curve will work? Keep in mind that the actual subfloor would extend another two inches due to the wall thickness.Click image for larger version
Name:	ImageUploadedByAirstream Forums1436980333.359288.jpg
teilhet is offline   Reply With Quote
Old 07-15-2015, 11:33 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
You might save a little time using your black tank as a pattern, and you might regret the short cut. Your black tank isn't custom fit to your shell, it just has the approximate shape of the planned trailer radius. I see a fair amount of uncertainty.
The only way to make sure your new floor matches the curves of your specific trailer is to use the trailer shell itself to create the pattern. Many people have the problem of an incomplete rear sheet and have to go about it this way. Use cardboard or a piece of thin masonite slipped under the trailer, and then trace the actual curve.
good luck.
Old 07-15-2015, 01:04 PM   #3
1960 22' Safari
Thanks for the good word. I. Was thinking along the same lines. I planned to pull the body up off the ground with a gantry and then lower it down to get a curve outline from the actual shell onto the actual floor. Your suggestion may do the trick though.
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Creating a replacement floor template from a sketchy predecessor... KCN Repairing/Replacing Floor &/or Frame 5 08-09-2012 09:10 PM
Help --need a '67 floor template pinkflamingoes Repairing/Replacing Floor &/or Frame 17 08-01-2006 02:11 AM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 06:28 PM
