Old 09-21-2015, 01:19 PM   #15
1967 26' Overlander
Spartanburg , South Carolina
Our 48 year old 26 footer is bowed. So am I after 74 years but we are both keepin' on. Basically a trailer is a complex beam supported by a fulcrum (axles) slightly rearward of its longitudinal center and the tongue jack. Weight of any magnitude away from the fulcrum will result in a slight deflection downward. Theoretically the tongue jack or the hitch will off set the deflection in the front half leaving a slight downward deflection of the rear end. I figure that is the reason many trailers are now built with mid baths and kitchens with the three tanks somewhere near the axles. A smart engineer designing an A/S would, you would think, build the rear with a slight upward deflection to compensate for the body weight behind the axles. Having said all that, keep in mind the motion over speed bumps and pot holes will cause the trailer to bounce and flex, and over time probably results in some downward deflection front and back. The main reason for carefully leveling the trailer when parked is to protect the absorption refrigerator from damage. I level from side to side using a 3' level across the A-frame with short boards under the wheels as needed and front to back with a bubble level attached to the side near the door. I then check the freezer with a round bubble level. It doesn't have to be perfectly level but should be within the inner marks on the glass.
Jacob D is offline   Reply With Quote
Old 09-21-2015, 01:30 PM   #16
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
Why don't you use the leveling technique which is used by Hitch Installers? Tape measure the outside rear end at the rub strip, then measure at the front the same way. They do this so the trailer is level, and then use tape measure to measure height of front/back middle of wheel wells.... which is very important to set up the hitch and weight distribution system.
I too cannot get a good measure with a level in the inside for the same reason. Your floor is fine...
glcmranger is offline   Reply With Quote
Old 09-21-2015, 01:46 PM   #17
NoNameinNM's Avatar
2016 28' International
Albuquerque , New Mexico
Perhaps we don't give them enough credit, then-- we have the slight bump at the axles, and the rear bedroom is a bit higher than the rest of the trailer.
NoNameinNM is offline   Reply With Quote
Old 09-21-2015, 02:06 PM   #18
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I just use a torpedo level on the sink counter - first level across then level lengthwise. I use the Anderson Camper Levelers too...
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 09-21-2015, 02:27 PM   #19
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Somehow it seems we are turning a simple task into NASA rocket science ....
.... leveling a trailer should not be rocket science .....
The fridge represents the defining need for being level.
To set-up your exterior bubbles for the first time use a bullet level on either the floor of the fridge or the freezer to level the trailer - then install your exterior bubbles (front to back bubble and side to side bubble) to reflect that the trailer is already level.
Thereafter level the trailer to the bubbles.
Close is good - dead on is easy to get from front to back - sometimes side to side will be a little off - that's OK.
In our little family the final leveling (front to back) is one of the last activities in a set-up - always followed by a welcoming Martini and ritual toast .....
End of story.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 09-21-2015, 02:28 PM   #20
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
A slight variation - Like Micheal above, I mounted the Level Master on the outside of the trailer front, but only after having used my smaller 18" level to determine I had the freezer floor level in all directions. With the Level Master set side to side, I then adjusted the Level Masters' screw for the fore/aft level to centered. I followed that by adjusting the circular bubble level in the power jack head (3 screws) to centered as well. Now, I don't have to enter the trailer to know when I am set correctly.
SeeMore is offline   Reply With Quote
Old 09-21-2015, 03:56 PM   #21
white laker's Avatar
2002 31' Classic
lanark , Ontario
Wow! leveling a trailer..... is it time to talk about 16" tires, hitches and Freightliner tow vehicles! enough!
Pete
Pete Crook
"Put it all behind you!"
white laker is online now   Reply With Quote
Old 09-21-2015, 04:15 PM   #22
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Ditto on Door Sill
Originally Posted by m.hony View Post
The guys at Jackson Center say to place a level on the entry door sill and use the tongue jack.
Have been doing this since owned my AS. Technicians at the dealership, (Billy Simms Trailer Town - Lubbock Texas) stated that this was the prescribed AS method.
tsunami is offline   Reply With Quote
Old 09-21-2015, 10:39 PM   #23
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
All trailers have front and rear sag because they are not built on a jig. The shell is set on a frame that then sags slightly with its weight and then the installed items add to this sag. Newer trailers have windows cut in the sides on a computer control cutting table before assembled in the shell. Even the older trailers had fairly accurate cutouts. Therefore, I use a torpedo level on the inside sill of the closest to middle window. That way, you can look in and check for level while setting up. Eery thing else will depend on some sag in all four directions. If you use stabilizers you can load them slightly to eliminate some sag. Don't load them more than necessary to stabilize. They are easy to overload, i.e., clutch ratcheting noise. If you have a long trailer with slide you may have to adjust the stabilizers to allow for the slide to clear the shell opening. Also, if your entry door is then hard to work you may need to readjust for that. My 35' is al flexible as a snake. Just like the inside of a large aircraft fuselage.
guskmg
Old 09-21-2015, 11:59 PM   #24
2015 25' Flying Cloud
Eugene , Oregon
Thanks for Many Ideas
There are so many people to thank, I don't know where to start. I am fairly good at side to side leveling ( I too have those Anderson red leveling things) and I know how to use the front jack to raise and lower the AS to level. I guess I was worried about the slope front and back on the floor from the axles. Many recommended I contact AS or the dealer while under warranty since it doesn't seem right to have that much of a slope in both directions. I agree, but Paula reminder me that I might be doing this floor measurement with either under inflated tires or not having the stabilizing jacks down. I will try all suggestions only with properly inflated tires AND the stabilizing jacks down (not over loaded). I suspect I already have my front bubble level set correctly for freezer lever. I will recheck the slope in the floor again, but many have indicated the flex is partially normal. I'll also call the dealer, especially since it is under warranty. Maybe I am splitting hairs trying for the perfect level front to back. Thanks again. Never imagined I would generate so many responses to my question. Lyle
ltorgy is offline   Reply With Quote
Old 09-22-2015, 07:56 AM   #25
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
From my trailer manual,
When you plan to stay in the same place for several days, weeks or months, you will want your trailer to be as level and steady as possible. Check the attitude with a small spirit level set on the inside work counter or the trailer hitch "A-Frame". (See Diagram Below) If a correction is necessary then YOU MUST LEVEL FROM SIDE TO SIDE FIRST This can he done easily by backing the trailer up one or more 2" x 6" boards. (See Diagram) We do not recommend placing tires in a hole for leveling.
LEVEL FROM FRONT TO REAR by disconnecting the hitch from the tow vehicle, putting the jack pad under the hitch jack and adjusting the jack up or down until you are level. Block or chock the wheels to keep the trailer from rolling. Use STABILIZING JACKS at all four corners as shown in the diagram to eliminate the natural spring action of the axles. Optional STABILIZING JACKS, whether manual or power, should only be used to stabilize trailer.
WARNING: Whenever the trailer must be lifted with a jack, as when changing a tire or leveling on very rough terrain, ALWAYS PLACE THE LIFTING JACK UNDER THE MAIN FRAME RAIL. A label is provided to indicate the proper position for the jack. NEVER USE STABILIZING JACKS TO LIFT THE TRAILER.
And
Any time the vehicle is parked for several hours with the refrigerator operating the vehicle should be leveled to prevent this loss of cooling. The vehicle needs to be leveled only so it is comfortable to live in (no noticeable sloping of floor or walls).
When the vehicle is moving the leveling is not critical, as the rolling and pitching movement of the vehicle will pass to either side of level, keeping the liquid ammonia from accumulating in the evaporator tubing.
The factory manual for the refrigerator says to use a level in the freezer section.
MICHAEL
Old 10-12-2015, 07:02 AM   #26
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Another vote for the Andersons... combine those with a level on the rock guard (that I look at in the rear-view mirror), and side to side leveling is a breeze. My disappointment will be palpable when I get to some campsite in the future that is more out-of-level than the Andersons can compensate for. I'm going to cut the nose off of one of them so that it'll slide between the tires easier.
I find the bubble level on the tongue jack to be worthless- sometimes the trailer pushes or pulls on the jack, and kicks it out of plumb. I have a dual level thing mounted on the tongue itself.
My floor is also bowed. When I re-did the rear bedroom, I built the bed frame like a large spar, which helped to solidify the back.
Since my trailer has the manual landing gear, I use my DeWalt impact driver to bring them up and down. BRRRRR-AP! It's done, and I feel so wicked for not having hand-cranked it!
SuzyHomemakr is offline   Reply With Quote
Old 10-12-2015, 08:16 AM   #27
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
"I will recheck the slope in the floor again, but many have indicated the flex is partially normal. I'll also call the dealer, especially since it is under warranty."
Are we all assuming that the floor was installed with any concern for it being level?.
As noted the fridge and tongue are where the the emphasis lies for us.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Best way to level & stabilize a '60 glw73069 Jacks, Stabilizers, Lifting and Leveling 4 07-15-2015 01:23 PM
Will accept BEST OFFER on front + back end caps of 69 Airstream Safari AmrcnDrifter Airstream Classifieds 0 01-24-2015 04:34 PM
Best RV Level Jobs tsunami On The Road... 18 07-26-2014 08:11 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
