| Try this
Are you looking for a sealant or an adhesive? The question sounds like you need an adhesive. A trick I learned from an old contractor is hot glue & Liquid Nails together. Put on the Liquid Nails where needed. Then put on dabs from the hot glue gun. The hot glue will hold instantly (3-6 secs), but will start to release it's bond after 6 months. This gives the Liquid Nails plenty of time to set up permanently. Just get the right Liquid Nails as there are so many to choose from.
Ricky
__________________ Toilet showers! Convenient AND refreshing. Nice. SleepTalkinMan.blogspot.com AIR 22749 WBCCI 2349 1974 25' Tradewind - no TV yet 1989 345 LE Classic Motorhome Courtesy Parking; 20 amp, water, dump, wifi 'tween exits 27 & 33, I-75
Reason: add info
