Old 08-25-2016, 05:53 PM   #15
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
Use an angle grinder inside the channel to cut the bolts. An oscillating tool will take forever or longer. Just tried an oscillating tool and bolts are too hard. Grinding wheel goes right through them.
Kemblkr is offline   Reply With Quote
Old 08-25-2016, 05:56 PM   #16
Kemblkr's Avatar
I pushed grade 5 bolts up from the bottom of channel, through the new subfloor and used nylock nuts. Not sure how you could do it without access to the underside. Had to have wrench on both sides to tighten.
Old 08-26-2016, 08:46 AM   #17
1966 24' Tradewind
Salt Lake City , Utah
Thanks!
Thanks guys! Much appreciated. Great advice.
dream-stream is offline   Reply With Quote
Old 08-26-2016, 09:05 AM   #18
1966 24' Tradewind
One more quick question. Are you talking a 4.5" angle grinder? Would i just angle it down into the channel? I've found a few 2" angle grinders that would fit into the channel, but not sure they're heavy duty enough for the job.
Old 08-26-2016, 02:41 PM   #19
1972 23' Safari
Camas , Washington
a link to a thread on how I removed elevator bolts, lots of ideas
http://www.airforums.com/forums/f36/...lts-99529.html
Pams72 is offline   Reply With Quote
Old 08-27-2016, 09:33 PM   #20
Kemblkr's Avatar
Once the word is removed you can just cut them out of the channel. If your wood is still intact and surrounding the bolt then you may have to get through the wood first. But no, don't angle down through the wood. Remove the lower aluminum skin so you can access the tops of the bolts. Try the previous mentioned thread. My process involved my wood being so rotten I was able to clear out the channel of all wood leaving only the bolts exposed.
Old 08-29-2016, 09:20 AM   #21
1966 24' Tradewind
Makes perfect sense. Thanks so much!
Old 08-29-2016, 09:24 AM   #22
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by Melody Ranch View Post
I got a hole saw......made a template tool (hole in a board).....drill out the area around the bolt. Lift out the flooring and then use vice grips to break the bolt...very easy.
We did the same, but without the template.
Shari
Old 08-29-2016, 06:13 PM   #23
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
On channel bolts I used a rotozip angle grinder with 1/16" metal cutting blade, nice angle cut through both bolt/nut until they simply fall apart. Very satisfying.
On doing blind floor attach, with belly pan on? Later Airstreams (My '73) used this type of floor fastener, I pre-drilled pilot holes and used a countersink bit on the plywood to accept the flat head - if you use these be gentle seating the screw, not much metal in the spars and I had one out of fifty or so strip the threads. The cutter-wings shear off on contact with the metal, I did not use them & snapped them off before setting fasteners.
It would be okay to increase the number of screws per spar, 8 or 10 inches apart, etc. etc.
Old 08-29-2016, 06:35 PM   #24
1968 20' Globetrotter
Rumford , Rhode Island
If yoy decide to go the vise grip method be careful on the outrigers. They will bend. I use 2 vise grips. One tight on the bottom. The other on the top to wiggle.
My question.... We are putting in the back section of our floor on our 1968 Globetrotter. I know that this might be a stupid question but does the wall stud sit on the outrigger or the floor. No wood left to tell. Is the wood notched around the stud ot do we need to raise it? There was a L bracket from the stud to the rear floor.
Steve and Deb
layback is offline   Reply With Quote
Old 12-03-2017, 06:25 AM   #25
MISSOULA , Montana
This is brilliant. I am really glad I just found this- it is going to make my day much more enjoyable! Thank you!
David S is offline   Reply With Quote
Elevator bolts????????????? 58BUBBLE Repairing/Replacing Floor &/or Frame 35 08-24-2007 10:50 AM
Where are your elevator bolts? byamcaravanner Repairing/Replacing Floor &/or Frame 9 07-17-2007 03:54 PM
elevator bolts tracker Repairing/Replacing Floor &/or Frame 2 12-13-2005 02:11 PM
