Old 06-18-2007, 07:23 PM   #1
2005 22' International CCD
Woodland Park , Colorado
Bent Frame on 2005 22' Intl - How bad is it?
Just removed the fresh water tank on our 2005 22' International we purchased in February to replace due to overfilling. See http://www.airforums.com/forums/f443...ank-33300.html . Tank came out easily, thanks to the advice from other forum members. However, once the tank and cover were removed we discovered a bent frame. There is no way this was caused by overfilling the tank, however we never would have noticed it had we not removed the tank as it was hidden by the tank cover.
The first two pictures are of the right side frame just forward of the wheels. You can see the bend in the lower section of the frame. Not seen is that the vertical section is bent inward, and there is about a 2" horizontal crack just behind the electrical lines (where you can see the rust spot). Picture #3 is the same section but from the outside. The crack is just above where the outer sub-floor starts (you can see a bit of rust there). Picture #4 is of the left side of the frame, from the inside, showing a similar but much smaller dent on the lower section of frame. No crack here and the vertical section is straight. The last picture is of the cracked floor caused by the overfilled water tank.
We are pretty disappointed in finding this on a 2 year old trailer that we've owned for less than 6 months. The funny thing is we never would have found it had we not had to remove the tank.
So.... How bad is it and what do we need to do to repair? Can we simply have the frame pounded straight and some reinforcing pieces of steel welded on? Can we leave it alone? (the crack makes me think no).
Please help. Appreciate any information you can provide. jk
Name:	Bent Frame Inside.jpg
ID:	39510   Click image for larger version
Name:	Bent Frame Inside3.jpg
Name:	Bent Frame Outside.jpg
ID:	39512   Click image for larger version
Name:	Bent Frame Left Side.jpg
Name:	Cracked Floor.jpg
JK3500 is offline   Reply With Quote
Old 06-18-2007, 07:38 PM   #2
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
Where the damage is...
It almost looks as if the previous owner/shop tried jacking the trailer up right there and then tried to bend it back into shape. I think that you should talk to Airstreams factory repair people and see if the frame is "heat treated". If it is then you cannont weld, If it is not heat treated then you could have a angle or strap welded over the crack.
How hard was it taking the tank out?
SafariSS is offline   Reply With Quote
Old 06-18-2007, 07:44 PM   #3
Removing the tank was pretty easy. Remove 3 brackets and the left side of the tank cover, Prop the left side of the tank up, drop the right, disconnect the hoses and pull the tank out. Took about an hour. the hardest part was disconnecting the fill hose and the hose pulling the water to the trailer. All the hoses were connected to the left side of the tank.
Old 06-18-2007, 09:10 PM   #4
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Cold fix ...
The lower C channel of your chassis frame was deformed, cold, by the force of water pressure. I'd clamp a thick flat piece of metal, perhaps a 1/2 inch thick rectangular bar maybe or a small section of railraod rail with the flat bottom down, to the inside of the C channel between the adjacent cross members. Then, with a 4 or 5 pound sledge hammer, pound the lower lip of the C channel, still cold, flat again. Repeat on the other side frame rail.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 06-18-2007, 09:33 PM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Looks to me like it's just the lip and not actually a bent frame, or I should say, what I was thinking a bent frame is. This should be fairly easy to get back into shape.
I was thinking that the whole side frame was also distorted.
Old 06-18-2007, 10:12 PM   #6
47WeeWind's Avatar
1948 16' Wee Wind
Denver , Colorado
Images: 20
... plus some heat for the crack
I jusr read your description and learned about the vertical crack, which is not visible in the photos. Have that crack repaired. I would imagine a welding shop could repair it, but to be on the safe side call Airstream customer service first to confirm that the frame rails can be welded.
Airstream Life
"From the Archives"
Old 06-18-2007, 10:55 PM   #7
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I don't think it all was the tank... it wouldn't bend the rail inward. That said, I would just pound up the bent c-channel, and then re-inforce the crack. A piece of steel welded to it would do the trick. Then cover it up, and forget about it. If the trailer is tracking straight, (and from your trip report, it seems to be), then you are good to go. Wonder what did bend the frame inthe first part though. Probably jacking in the wrong place is my guess in the abcense of an accident.
The OSB is kind of blown out. I'd either cut it all out and replace it, or sister a large rectange up under the OSB (if there is room) with constructive adhesive and screws.... don't go through the floor though!
Marc
Old 06-19-2007, 01:52 AM   #8
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
do you think plywood would handle the pressure better than OSB?
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 06-19-2007, 05:39 AM   #9
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
I thought all Airstream floors were made of plywood and not particle board as shown in your photos?
ArtStream is offline   Reply With Quote
Old 06-19-2007, 06:31 AM   #10
_
osb was used as flooring in the 16s and 22s in '05...
now just the 16s. a single sheet.
take a few more pics and send 'em to j/c...
or have an experienced service shop look.
agree the area should be reinforced.
also need to weigh the unit...
not much carry capacity on that mode as i recall.
cheers
2air'
Old 06-19-2007, 06:50 AM   #11
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
All the advise on repairing the frame sounds good to me. The OSB floor however, may not return to its original flat surface so a relief cut following the crack may be in order to let the floor to set flat again. Before installing a reinforcment doubler double check and see if they will be enough room for the doubler between the tank and floor before installing.
Old 06-19-2007, 01:58 PM   #12
Thanks for that tip. we were debating how to repair the floor. we were looking at simply attaching a reinforcement piece from the bottom to avoid having to cut up and replace the floor covering. the downside is a ridge will still remain in the floor from the crack. will try cutting a relief along the crack and see if that helps. if so, i am fairly certain a 3/8" piece of plywood would fit between the tank and floor. if needed, i could remove some of the styrofoam on the bottom of the tanks to help it fit.
would it be best to cut the reinforcing piece flush to the front and back cross rails or do i need to leave a gap?
btw, i am in contact with airstream on the frame damage. sent them some pics and they are going to get back to me with some advice... jk
Old 06-19-2007, 04:53 PM   #13
Aerowood's Avatar
Arvada , Colorado
Its not inportant that the doubler be flush with the cross members just as long that you have a few inches of doubler on each side of the crack, 4 inches would be a minimun for me if you can achieve that.
Old 06-19-2007, 06:04 PM   #14
Aluminut
2004 25' Safari
. , Illinois
I could swear our 2003 19' had OSB as well. Maybe that was a change for the '05 model year.
how to check for frame rot ? oldvws Repairing/Replacing Floor &/or Frame 28 03-02-2007 07:37 AM
Bad Problem w/ Water Pipe rroessler Fresh Water Systems 20 06-05-2006 11:23 AM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Trailer Frame Joyce K Glass Repairing/Replacing Floor &/or Frame 1 10-02-2002 11:04 AM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 05:49 AM
