Old 09-07-2009, 01:09 PM   #29
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Interesting, this thread from 2 years ago... We had a '02 International. Had problems with the laminate popping off EVERYTHING and had the service bulletin advising us to get some frame work done to strengthen it. That was a clusterbuck if I ever saw one... but anyway, we always thought the design of the '02 International was really nice had they only took care of the QC issues. It was like a very cool picture but the reality of it left alot to be desired.
I can't count how many emails we had back & forth between A/S and the then Airstream website/forums (that have since disappeared). We ended up trading for an '05 30' Classic which had significantly fewer QC issues (thank god)... The '02 International, frankly, scared me because of the problem/issues it had.
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 09-20-2009, 07:49 PM   #30
Escondido , California
I Know this is over now in your mind, but my guess is this trailer was tied down on a tow vehicle. They over tightened it and when it bounced on rough road it did it in.
celsian is offline   Reply With Quote
Old 09-22-2009, 11:40 AM   #31
2005 22' International CCD
Woodland Park , Colorado
You are correct. The rest of the saga can be found here:
http://www.airforums.com/forums/f463...ars-45839.html
The downside is when making the first repair the Airstream factory assured me my towing setup was appropriate. 1 year later....
I now run without WD bars. So far so good... jk
JK3500 is offline   Reply With Quote
Old 09-23-2009, 10:59 AM   #32
2003 22' International
hillsboro , Texas
running without WD bars sounds interesting. background... i have had a LOT of problems with frame cracks with my 2003 23' int. the factory has replaced my frame once, countless patches, welds and factory kits on the new frame with no help. still the frame is a weak point. but running without the bars may ease the strain on the trailer frame somewhat but i wonder if the total stability will be compormised. the front end of the tow vehiclel will not have the correct weight distribution.
DON GUBRUD is offline   Reply With Quote
Old 09-23-2009, 12:18 PM   #33
_
Originally Posted by DON GUBRUD View Post
...i wonder if the total stability will be compormised. the front end of the tow vehiclel will not have the correct weight distribution.
don
the o.p. for this thread is towing with a 1 TON truck (srw) and was using 1000 lb w/d bars for a ~550-600 lb tongue.
so running without spring bars will have virtually NO effect on w/d (the steering axle load) because of the payload capacity of his 1 TON truck...
and the relatively small tongue mass of the poorly-built-no-belly-pan-osbflooring-weak-framed 22 footers.
he may have issues WITHOUT sway control,
but there are hitches (or lighter w/d bars) that solve the sway problem WITHOUT added w/d stress to the frames...
______________________
otoh YOUR experience with the 23 footer (i think u mean 22) being towed by a TINY asian truck is interesting...
and certainly REFUTES the silly notion that TOO MUCH TRUCK is the cause of these problems...
http://www.airforums.com/forums/f36/...ure-48105.html
and NO w/d bars or zero tension with YOUR COMBO would clearly UNLOAD the steering axle of that 'yota...
which is NOT a good solution for your rig.
the issue was and still IS that a/s is using marginal frames (IN-adequate)...
combined with LESS than ideal brittle shells and FEWER connections between the 2.
everyone is frantic about the corrosion issue,
when the REAL concern (ok make a list) should be clearly inadequate basic structure of many a/s models.
for more out of body experiences read here,
http://www.airforums.com/forums/f36/...ion-35237.html
and beware the cracks are real and may be growing...
and it's NOT the bike racks as many of the rear sag threads MISLEADINGLY suggest...
it's the stickers...
DO NOT PUT ANY STICKERS on the the bumper or rear window, it's too much stress for the semi mono coque design...
cheers
2air'
Old 09-23-2009, 04:52 PM   #34
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Ha! Then the "caution, wide load" stickers on my rear may be the source of my crack?
Sorry, couldn't resist!
Throughly tongue in cheek...
Marc
Old 09-23-2009, 05:20 PM   #35
_
Originally Posted by 3Ms75Argosy View Post
...Then the "caution, wide load" stickers on my rear may be the source of my crack?...
depends, was the sticker balanced first?
caution w i d e l o a d stickers on rear end cracks...hummm.
i see a thread coming and a hole new product line.
cheers
2air'
Old 09-23-2009, 05:45 PM   #36
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
cheers
2air'
2air' nice to see you're back! I for one have missed your posts.
Annette
bullydogsmom is offline   Reply With Quote
Old 09-24-2009, 08:47 PM   #37
don
cheers
2air'
Thanks for clarifying 2air. Yes, I am towing with a 1 ton, which barely notices the trailer tailing behind, especially as I tow below 65 mph always. That probably would not be the case with a 1/2 ton or lighter TV.
Your points are right on the money. The frame is definitely the weak point, on my trailer at least (likewise with Don).
I have also removed all stickers from the rear of the trailer...
Good to have you back on the forums. Your insight, honesty and wit has been missed. jk
Old 09-24-2009, 09:45 PM   #38
E Pluribus Aluminus
Jaxon's Avatar
1967 22' Safari
2005 30' Classic
Rockport , Texas
cheers
2air'
"hole" new product line, eh...?
...stamped, pressed or... uh... extruded? :
Bill & Kim
how to check for frame rot ? oldvws Repairing/Replacing Floor &/or Frame 28 03-02-2007 08:37 AM
Bad Problem w/ Water Pipe rroessler Fresh Water Systems 20 06-05-2006 12:23 PM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 01:53 PM
Trailer Frame Joyce K Glass Repairing/Replacing Floor &/or Frame 1 10-02-2002 12:04 PM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 06:49 AM
