Old 07-22-2009, 10:35 AM   #1
Bent Frame: Need Advice
I was releveling my 65 Globetrotter trailer and forgot that the right (door side) stabilizer (scissors jack) was down. Lowered right side and apparently bent frame. The door won't close properly now.
Any ideas? Anyone else had this problem and can tell me how to correct it?
Thanks for your help in advance.
thombrad is offline   Reply With Quote
Old 07-22-2009, 11:32 AM   #2
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
Since you know when and how the problem was created perhaps you could duplicate what happened, only leave the OPPOSITE stabilizer in place. You'd need to be very careful and take it really slow, but it just might work.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 07-22-2009, 03:35 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would be reluctant to try and straighten it by applying force to the other side. The metal in your frame was only .100 whenit was new and has most likely lost a bit over the years. If you are inclined to attempt to straighten the frame I would drop the pan so you can see just where the bend is. If you have a means of chaining the frame down either side of the bend you could jack up at the bend point.
However if the frame bent it is most likely time to slide some new material in the frame. This is a common method of supporting the older frames.
2004 Excursion 4x4
bent frame, door not closing properly, leveling, scissors jack
Bent Frame on 2005 22' Intl - How bad is it? JK3500 Repairing/Replacing Floor &/or Frame 37 09-24-2009 08:45 PM
Color advice - A-frame, wheelwell Shangri-la Clearcoat, Exterior Paint & Trim 8 04-06-2008 12:41 PM
Need some advice on PO frame work and rear end sag catzdragon Repairing/Replacing Floor &/or Frame 15 10-10-2007 08:50 PM
Bad axles, rough road, bent frame Lumatic Axles 0 05-21-2007 08:24 PM
Jacked in the wrong spot and need body/frame advice ldetsf Repairing/Replacing Floor &/or Frame 71 11-19-2006 10:02 PM
