Old 12-16-2005, 09:27 PM   #1
I love Airstreams...
leefields's Avatar
1989 29' Land Yacht
Haines City , Florida
Talking belly pan ....needed....or not?????
do i need a belly pan....i would prefer to replace entire floor....there is enough rot....i want to cover with 5/8 marine plywood....sprayed top and bottom to seal....and spray bottom with an expanding foam....something along the lines of a bedliner coating........i would like to run electric lines via conduit along the frame....
i am in the orlando area and have stripped entire to the shower stall and toilet....so now i have to consider this....seems like a belly pan is not really needed.....correct me ....please
1953 Spartan Mansion
Ram 3500 DRW LB SuperCrew
PCS Professional Coach
AIR# 6366
leefields is offline   Reply With Quote
Old 12-16-2005, 09:54 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Weeeeell, not exactly 100% necessary....but definitely a good thing for protecting the bottom of your floor, keeping things covered, preserving originality, and aerodynamics.
The bellypan itself has little or no structural purpose. You will have to have a belly wrap, otherwise the entire trailer will look incomplete, might as well connect the wrap with straight sheets to complete the repair.
In other words, put it back after, or we'll take your trailer away!
Uwe
www.area63productions.com
Old 12-16-2005, 10:11 PM   #3
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
It's not needed for any structural reason but it is one of the traditional things that helps make it an Airstream. On the other hand, Airtream itself, 4 or 5 years ago and just for a short while, put out a model without a belly pan.
I would go to the trrouble of putting it back on. It will protect things, look nicer and ride smoother.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 12-16-2005, 10:55 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
From one '64 GT owner to another...
Hang in there & do it right!
Besides, with road debris & moisture the wood flooring even if saturated with sealer, will be more subject to damage & eventual failure without a belly pan. Your trailer has survived 40+ years, why, after putting all that work into it, wouldn't you want to protect it as best as you can to give it a chance at another 40? It's like going to the trouble of baking a cake and not frosting it ~
Shari
Old 12-17-2005, 06:21 AM   #5
2006 30' Classic
Farmington , New Mexico
Images: 14
If you don't mice won't have a place to build their nest. Poor little things !!!!
pieman
Mike Lewis is offline   Reply With Quote
Old 12-17-2005, 12:34 PM   #6
aztlanco's Avatar
El Paso , Texas
Send a message via AIM to aztlanco
Leefields;
Let's not forget the insulation between the floor and belly pan. It's there to help you stay cool (in Fla.) and toasty up North.
Ernie,
'58 Traveler, 18ft.
aztlanco is offline   Reply With Quote
Old 12-18-2005, 05:44 PM   #7
Johndigbydog's Avatar
1966 22' Safari
Eagle Lake / Eastport , Florida / Maine
johndigbydog@verizon.net
Hi- Am wondering if you have finished the floor project yet...I have a 66 Safari and am preparing to start mine. I am in the Lakeland area and would appreciate a look-see of the project if possible. Thanks John
Johndigbydog is offline   Reply With Quote
Old 12-18-2005, 09:08 PM   #8
1977 27' Overlander
Huntsville , Alabama
Send a message via Yahoo to dustyrhodes
Question Floor Replacement
I am contemplating floor replacement next. I think this is the time as I need to ensure the integrity of my frame. We are slowly repairing the leaks. There are no longer any puddles inside when it rains.
We have almost everything out now, however the interior skins are still on and I am reticent to remove them to replace the floor. I now have a visual on the C channel as you can see from the rusted bumper. I have read several forums about replacement with interior skins off and with the top removed although I can not imagine how that is done. I also read that some restorers have replaced the floor with the interior skins on. I need a weigh in.
HELP! please
I am still foggy on which is the best way to go. I have developed another great phobia. I am afraid that I will keep taking the Overlander apart and have nothing left to work with but dust.
On a brighter note, 2 of our fantastic fans are in since we had a mid 50 degree day to seal them with vulkem. They are awesome. I read that it was possible to use tin snips to enlarge the opening to accomodate the larger vent. Several blisters later - I can testify to a Rotary-Pneumatic-Cutting-Tool-3000, kindly provided by the Auto Hobby Shop. Cut my work down for 2 hours to about 2 minutes.
Sometimes I marvel at technology and sometimes I just marvel! To add to the madness we are simultaneously rebuilding a motorcycle in a box 1974 Harley Sprint - since I can't afford the deisel for my tow vehicle.
Great Holiday weather in Huntsville, AL
Jennifer
ID:	17159   Click image for larger version
dustyrhodes is offline   Reply With Quote
Old 12-18-2005, 09:12 PM   #9
1977 27' Overlander
Talking Oops
I am very bad with attachments!
Old 12-22-2005, 01:31 AM   #10
1973 31' Sovereign
Portland , Oregon
Images: 22
HELP! please
Jennifer
Jennifer,
I definitely favor floor replacement with the body in place. With your vintage rig and the way the u-channel/c-channel is constructed it would be dificult (maybe impossible) to take the body off of the frame without unfastening the body from the u-channel which does not seem like a good idea to me at all unless there are other circumstances involved. Leaving the body on gives you a covered place to work too. Check out my posts for details of how I have done it. Also feel free to ask specific questions as you get further along. Someone on the forums will usually come up with a good answer.
Malcolm (malconium)
malconium is offline   Reply With Quote
Old 01-09-2006, 12:15 PM   #11
ankornuta's Avatar
Lowell , Massachusetts
Images: 22
HELP! please
Jennifer
I too have a 26 footer; a two-door 1958 Cruiser. I've been prepping to lift the body for a while now. Last weekend I removed the lower interior skins, this weekend I removed the rest, and this upcoming weekend I'll be lifting the body. I can tell you that by removing the lower interior skins the "clamshell" design suddenly clicked in my mind. I would have to say that removing at least the lower interior skins will make your floor replacement MUCH easier.
ankornuta is offline   Reply With Quote
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
where belly meets floor meets shell JrnymnJay Repairing/Replacing Floor &/or Frame 6 01-09-2006 12:05 PM
Fixing the Floor 61BambiCanada Repairing/Replacing Floor &/or Frame 6 01-06-2004 09:21 AM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
