Old 12-11-2015, 03:07 PM   #1
vanster's Avatar
1967 17' Caravel
Oakland , California
Belly pan hell
We are trying to fabricate new corners for our 67 Caravel
So far we have made (4) corners for the left rear and none of them fit right .
We have used the original as a pattern, made our own pattern, made a buck, used 025 then now to 032. No matter how we attack it we can't seem to get the compound curve correct. Any tips?
vanster is offline   Reply With Quote
Old 12-11-2015, 03:39 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It is an art that often takes years to develop.
I wish I could be more help.
Brevi tempore!
Old 12-12-2015, 09:39 AM   #3
vanster's Avatar
1967 17' Caravel
Well said
I guess I need to up my budget on buying aluminum sheets
Old 12-12-2015, 10:22 AM   #4
Tuco's Avatar
1988 32' Excella
Ojai , California
I would suggest a trip to one of the small airports in your area to discuss the issue with someone who fabricates aluminum for a living. I know several people at Santa Paula Airport that could help, but they are too far away from you. Find an airport with vintage aircraft that need maintenance and you will find the help (and tools) you need.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline   Reply With Quote
Old 12-12-2015, 06:54 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Boy do I feel your pain. The rear corners on the 60s trailers are a bear to fabricate. Luckily they are generally flat and out of sight. But the front "banana wraps" would be impossible without an English Wheel and lots of practice.
The decreasing radius curve from the side to the rear bumper makes it hard. One mistake I made was not having enough angle to keep the edge of the sheet parallel with the frame member. I almost wanted to have an attachment "sleeper" along the frame rail so the corner piece could be attached to it as a starting point. As it is the corner piece is not attached to the frame rail.
David
Name:	1311 Belly Rear Wraps.jpg
ID:	253778   Click image for larger version
Name:	1406 Belly Corner Tabs.jpg
Old 12-17-2015, 10:12 AM   #6
GuitarmanFL's Avatar
1972 27' Overlander
Orlando , Florida
Would it work any easier if you cut small strips, and piece them together? Compound curves are a bitch!
GuitarmanFL is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 06:58 AM
Belly Pan Gaps? ajjohnsons 2003 Safari 6 07-22-2003 07:16 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
