Old 03-20-2011, 07:29 AM   #1
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
Before and after frame photos! (Lots)
The restoration begins! Wanted to show everyone before and after photographs of the work Colin Hyde did to our trailer. We will be taking her home soon to insulate, wire, and replace interior panels.
ID:	124934   Click image for larger version
ID:	124936   Click image for larger version
ID:	124938   Click image for larger version
ID:	124940   Click image for larger version
2vets is offline   Reply With Quote
Old 03-20-2011, 08:00 AM   #2
1994 30' Excella
Mississauga , Ontario
Looks good. My only comment is that from what I have seen over the years, no matter how the underbelly is installed water gets in. If the space is filled with fiberglass insulation it will get wet and stay wet. I don't think that is good. My next major project is to remove my belly skin and deal with the insulation. I'll likely remove it and install one and a half inches of some rigid panels up against the floor.
Good luck with the rest of your rehab. It will be a lot of work but worth it.
Al
Al and Jean
TAC ON-3
Old 03-20-2011, 08:11 AM   #3
Jim & Mitzi's Avatar
1990 34' Excella
1990 29' Land Yacht
Americus , Also Valrico, Fl
The comments on fiberglass insulation holding water = rust are so true. I'm going with the rigid panels attached to the bottom of floor or the sprayed / expanding insulation and try to ensure that any water that does get in can get out ASAP. JC
Jim & Mitzi is offline   Reply With Quote
Old 03-20-2011, 08:57 AM   #4
1994 30' Excella
If you spray in rigid insulation you may create a problem. One it is not easy to remove if necessary.
The other thing is that you may create spots that still get wet and then don't breathe enough to dry out.
Al
Al and Jean
TAC ON-3
Old 03-20-2011, 09:12 AM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
I was looking at the shed the frame is in. What's the whole story on that?
Old 03-20-2011, 09:22 AM   #6
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
It's a 32 X 14 X 12 high RV shelter that is inside a warehouse.
Colin
Colin H is offline   Reply With Quote
Old 03-20-2011, 09:23 AM   #7
2vets's Avatar
1960 24' Tradewind
Colin works out of a big unheated warehouse. He has multiple small garage shelters within it that he can heat easily as he is working on that project. Pretty nifty way to conserve heat in the frigid north! Hoping Colin will chime in on insulation questions but I know he used automotive undercoating application to protect the undersides. He used reflectix underneath the pick insulation.
Old 03-20-2011, 09:31 AM   #8
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Looking good 2Vets.......The TW is going to like that solid new frame for the next fifty years.
safari62 is offline   Reply With Quote
Old 03-20-2011, 09:32 AM   #9
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Al
That is probably because the water comes from above, & we all know that "s**t runs down hill". It will stay wet because it is continually fed. The complete interior of this body has been seam sealed & it will be leak tested before completion.
Colin
Old 03-20-2011, 09:35 AM   #10
2vets's Avatar
1960 24' Tradewind
oops I meant pink not pick insulation!
Old 03-20-2011, 09:58 AM   #11
pbearsailor's Avatar
Port Hadlock , Washington
Unreal how bad your frame was--maybe those salty New England roads?
Colin's rotisserie is just way cool. Anyone who has done frame or holding tank or bellypan work is just plain envious.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 03-20-2011, 10:02 AM   #12
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
The complete frame had the rust removed with a wire brush on a grinder, then the rusted out portions of the rails were cut off & replaced with new steel. A new coupler was also installed because the original one was quite worn & it had numerous crude modifications done to it over the years. The "A" frame was closed at the front, below the coupler to stop water from entering in the future. All of the original frames are left wide open in this area just begging to rust out from inside. After all of the frame repairs & upgrades were complete, "rust converter" was applied to the whole weldment. After that, it was sprayed with POR15 & as you can see, it was done on my rotisserie, so I have easy access to every nook & cranny. Then several quarts of enamel paint were poured inside the main rails & the whole assembly was rotated & tipped up & down, rotating along the way in order to spread the paint on the complete interior of each rail. After all of this, the floor was installed & Automotive Undercoating was appied to the complete chassis & underside of the floor.
Is it going to rust out again, perhaps, but not in the owners lifetime...............unless they park it in a brackish swamp
Colin
Old 03-20-2011, 02:36 PM   #13
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
You don't need ice-melt or agricultural fertilizer runoff to burn your mild-iron into dust - Acid Rain is a huge factor on iron, any power plants, autos and anything else burning upwind - including China now - exhales iron eating acids .
Normal rainwater used to read about 5.7 pH while acid rain reads pH of 5.0 or lower. Coffee is around 4.9 pH, average rain in the US is now 4.5 (may be higher downwind of urban areas) and orange juice is 3.7 .
Here in Minnesota I seen weak spring squalls of low-pH rain kill 40 pounds of fresh grass seed just spread out, and burn through the knees of Levi denim pants where I peeked under my truck and got the knees wet, days later the knees just turned to gauze.
Anyhow - just a factoid to toss out. I think the economists plan on 2-3% annual losses of capital assets from the steel portions' corrosion alone, our vintage trailers sure fit that model...
Old 03-20-2011, 02:43 PM   #14
2vets's Avatar
1960 24' Tradewind
Hey no fair Colin- now that mud season is upon us my backyard does have a brackish swamp resemblance!
