Old 12-04-2015, 07:32 PM   #1
silverbacksurfer's Avatar
2005 25' International CCD
Glendale , California
Battery box upgrade
I'm not a master mechanic and I don't own a boat restoration facility just a homeowner with some handyman skills. Also I don't have a huge shop. My batteries needed to be replaced so I decided to upgrade to the 6 volt golf cart batteries which led to repainting the tongue. here's a couple photos, ended up getting a little sand blaster from Harbor Freight and used a chemical stripper for the paint.
ID:	253366   Click image for larger version
silverbacksurfer is offline   Reply With Quote
Old 12-04-2015, 08:20 PM   #2
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Thanks for the photos.
Did you spray the final coat or brush it on? What kind of paint did you use?
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 12-05-2015, 08:38 AM   #3
Battery box upgrade
Here's a photo of the tongue with two coats of paint on it also the primer that I used and the paint both from Dunn Edwards I had them match the color as close as possible to the factory color and the paint gun that I bought at Harbor Freight for $29 this threads to help those that don't have the ultimate shop and set of tools and advanced restoration skills which I don't showing you what's possible with a little elbow grease. Also the aluminum extension on the battery box is 1x 2in aluminum tubing that I had welded going to just screw it on to the lip of the battery box
Old 12-05-2015, 09:03 AM   #4
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
That looks better-than-new. Nice work! Joe
jayseejay is offline   Reply With Quote
Old 12-05-2015, 09:25 AM   #5
Battery box upgrade
Thanks spent most of the time with the harbor freight little tiny sandblaster.
Old 12-05-2015, 09:38 AM   #6
Battery box upgrade
Here's a couple more photos related to the whole project a new split panel for the trailer the 120 panel to divide the load when dry camping and new 12 volt distribution panel and new inverter with an automatic transfer switch.Removed the parallax ACDC converter charger.
ID:	253385   Click image for larger version
Old 12-05-2015, 10:29 AM   #7
Alphonse's Avatar
Lower Alabama , USA
Nice paint job!
Looks like you did spend the effort to clean it up really well and prime. Turned out very nice - likely much better than original.
Alan
Air #64439
TAC AL-8
2018 Canopenian
Old 12-14-2015, 01:49 PM   #8
Battery box upgrade
All finished with the battery box upgrade , 6 volt batteries installed, repainted the tongue. Ended up getting A new Electric tongue jack didn't want to deal with the rust on the old one.
ID:	253858   Click image for larger version
Old 12-15-2015, 03:04 PM   #9
jpons's Avatar
2008 20' Safari SE
Bangor , Maine
How did you end up attaching the box extension to the original box lip?
jpons is offline   Reply With Quote
Old 12-15-2015, 05:07 PM   #10
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Looks fantastic! Excellent work!
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 12-15-2015, 10:02 PM   #11
Battery box upgrade
I clamped my new top extension to the battery box drilled it from below and used stainless steel sheet metal screws. Its just screwed through the lip of the battery box. 2 inches tall and just barely has enough clearance to open without it hitting the trailer.
Old 12-16-2015, 07:55 AM   #12
GuitarmanFL's Avatar
1972 27' Overlander
Orlando , Florida
Looks Great. I too am planning on blasting the tongue and repainting once I finish replacing my floor. 27' Overlander
GuitarmanFL is offline   Reply With Quote
Old 12-17-2015, 12:37 PM   #13
jpons's Avatar
2008 20' Safari SE
Bangor , Maine
Thanks for the response. You did as I had suspected you had done. I am contemplating doing the same as you so I was curious to see what you did.
Thanks again.
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
Battery box and battery location(s) ehodg66 Batteries, Univolts, Converters & Inverters 4 04-22-2014 07:39 PM
Cracker box after cracker box. rebel beck Our Community 15 06-07-2006 07:53 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
