Hi there airstream family,
I'm humbly requesting some specific help for the replacement of my bathroom subfloor in by 75-76 Argosy '26 RB. I am thinking I will not be able to fit a new piece in the way I removed the old piece. I'm not planning on removing all the interior skins as we plan to keep the "bedroom" intact durning remodel. It seems though, in order to get a good look at the c channel, at least the bottom skins in the bathroom need removing?? If attempting to slide the new piece in from the outside is the best option, what steps do I need to go through to do that?
When I look at the exterior, I see a rail separating the exterior skin from the belly pan. I'm assuming that comes off? Does the entire circumference need removing? Do I need to remove the bumper? Should the belly pan be removed? Sorry, I know these are elementary questions- kindergarten even but I want to make sure I do the right steps to get the repair done well but without doing extra work that necessitates more demo than I need. Thanks in advance!
