Old 08-08-2004, 01:02 AM   #15
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Originally Posted by Safari Tim
What a supurb job! Looks great.
Does anyone know how this product hold up? Any special care needed when using a refinished tub, sink, or shower pan?
Tim,
Mine is holding up really well. Even where the shower hose ( metal) rubs on the finish, ther is no sign of wear.
We've been to Baja, had sand crusted babies in there, and all sorts of traffic in the bath ( mine is a wet bath where you walk inside the shower pan every time you enter the bath"room") with no problems or peeling so far.
I had mine done by a refinishing company, but I guess the 2-part store bought stuff is just as good.
Uwe
Old 08-08-2004, 01:06 AM   #16
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Originally Posted by uwe
Tim,
Uwe,
If you don't mind me asking, (even if you do it's too late ) how much did it cost to have it professionaly redone?
If my memory serves, you had your bathroom totally disassembled didn't you? So I suppose you had it done then. I would like to have something done in place so I don't have to dismantle the bathroom.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Safari Tim is online now   Reply With Quote
Old 08-08-2004, 02:14 PM   #17
uwe
418
uwe's Avatar
Images: 40
Tim, I paid $ 250.00 for the bath pan, the toilet riser cover, and the vanity top/sink assembly. This includes several hours of prep work.
I then decided to have them do the tambour as well, and paid a little extra for this. I forget how much.
It is definitely cleaner to do it once it is removed, but it is possible to do it with everything in place, especially if you're using the brush-on system mentioned above.
I can not see spraying the parts while they are in place, and get a good result. It's too tight, and overspray would be inevitable, resulting ina hazy finish.
Uwe
Old 08-12-2004, 08:23 PM   #18
Safari Tim
Safari Tim's Avatar
Images: 35
That sound pretty resaonable to me. Expecially with the results we're seeing.
Thanks for the info!
-Tim
Old 02-03-2005, 03:55 PM   #19
JIM ELLIS
JIMBO
JIM ELLIS's Avatar
Profile:
Thumbs up Bathtub Removal
I cannot figure out how to remove the bathtub from its drain pipe. Do you how I can reach the nut attaching the pipe to the drain assembly?
JIM ELLIS is offline   Reply With Quote
Old 02-03-2005, 11:13 PM   #20
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
The chrome bezel in the bathtub IS the nut. It's threaded into the P-Trap. Put a couple of screwdrivers into the drain and cross them and you should be able to turn it out.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-04-2005, 05:11 AM   #21
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Talking
I had to warm up the pipe dope on mine a few weeks ago to get it to turn. Broke one of the inserts prior to applying heat, it did come out. I found a replacement at Home Depot.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 02-05-2005, 06:34 AM   #22
PizzaChop
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
Bathtub Removal
Well, was I surprised to find this old thread pulled off the shelf!!
I actually made a tool to unscrew the the tub drain from a P-trap. I used a pipe about 1-1/4" diameter and cut four 1/4" notches (12, 3. 6, & 9 o-clock positions) that would fit into the drain strainer (nut) and was able to break it free.
It was kind of a pain to put it back and I still don't have it tight enough, just haven't gotten around doing it. (There's a slip joint at the P-trap that's pretty hard to get a good grip on.)
(Don't worry though, removal is always the easy part!)
The "Tough As Tile" is still holding up, although there a couple of spots I wish I'd sprayed thicker. It cleans easily and looks so much better than the old yellow finish. The hardest part was disassembly and prep.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 09:01 AM
Wheel Well Restoration Pics? CanoeStream Wheel Wells 2 02-16-2004 04:27 PM
advice wanted for bathroom sink replacement Shelby Copeland Interior Restoration Forum 8 12-25-2003 08:06 AM
Pergo in the bathroom Chuck Floor Finishes 8 08-05-2003 06:13 PM
Help! Bathroom Restoration jdleezer General Interior Topics 3 07-26-2003 12:59 PM
