Old 05-06-2009, 04:30 PM   #1
Silver Bullit
timmy67's Avatar
Profile:  1985 25' Sovereign
Edmonton , Alberta
Bamboo Flooring
Unfortunately I am pressed for time and cannot do a full search so I am asking for help. We are currently doing a remodel on our 1984 Soverign which includes ripping up the carpet and replacing it with something better. My wife has suggested bamboo which we both love. However, the bamboo she brought home to look at is actual hardwood and I'm afraid that there may not have enough flex in it as you travel. Any and all thoughts are appreciated. Thanks in advance.
Tim
timmy67 is offline   Reply With Quote
Old 05-06-2009, 05:17 PM   #2
Profile:  1950 28' Whirlwind
Philadelphia , Pennsylvania
This is a great question re: flooring. I am refurbishing a unit and have been looking at the bamboo flooring by Foundation Flooring from Green Depo in NYC ( I am using all non-toxic materials). You may want to contact them re: the flexibility of the product. I need to know that too. Thanks Lisa
Lisa D is offline   Reply With Quote
Old 05-06-2009, 07:07 PM   #3
truckasaurus's Avatar
Profile:  1961 26' Overlander
Airdrie , Alberta
Images: 24
Hi Tim
I'd skip the solid bamboo, it's an interesting material, but being similar to wood (it's a grass) it may expand and contract too much for your application. Going from a very dry Edmonton climate to somewhere more humid will have that floor shifting over time.
Also as you point out it will be less flexible than other alternatives. To get around the flexibility problem maybe try bamboo as an engineered material (like plywood). Installed as a floating floor it may work better, you could even try the HDF backed variant, it's tested immersed in water for quite some time and is used in renos of the big motor homes, but it's still heavy stuff.
I have installed bamboo with staples (2") and like typical 3/4" hardwood this works great in a climate controlled home but going down a road, that would be something I wouldn't try.
For my own project I'm keen on Marmoleum or cork sheet which is ironic considering I am a hardwood installer...
preparing for the maiden voyage in 2010...
truckasaurus is offline   Reply With Quote
Old 09-04-2009, 06:37 PM   #4
Profile:  vestral , New York
bamboo is a new choice in flooring. It's ecologically friendly, with the beauty of traditional wooden flooring, plus simple laminate-like installation.
scottsdale floor covering
marvin-r is offline   Reply With Quote
Old 09-04-2009, 06:45 PM   #5
cameront120's Avatar
Profile:  1972 25' Tradewind
Think of the added weight to your trailer. I'd rather give that over to supplies.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
cameront120 is online now   Reply With Quote
Old 09-04-2009, 07:44 PM   #6
Roadrunner's Avatar
Profile:  1978 29' Ambassador
1960 26' Overlander
Indiana , Pennsylvania
Bamboo Floating Floor
I stopped just today at Lowe's to see what they had in bamboo flooring. We are in the process of replacing the floor in our 78 Ambassador. The floating floor style should work fine. It is flexible and should hold up. We are probably going to go with cork rather than bamboo. Both are only about 3/8" thick...that should address the weight issue. Perhaps someone in the forum would share pictures of their bamboo/cork floors.
Roadrunner is offline   Reply With Quote
Old 09-04-2009, 07:50 PM   #7
Area 63 Productions
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Orange , California
Send a message via Skype™ to Area63
I have used cork flooring in several client projects. Pics are on my website.
The flooring in my favorite trailer, the 1963 Overlander, has held up extremely well over the years. It's been to Baja, bicycle events, beaches, mountains, desert and cities. So far, it appears to be a near perfect flooring material for a mobile environment. Cork Rocks!
Uwe
www.area63productions.com
Area63 is offline   Reply With Quote
Old 09-04-2009, 08:14 PM   #8
Mexray's Avatar
near Lodi , California
Airstream Registry
We used the Prego Indian Tigerwood laminate flooring - it's foam backed, and 'floats' over the subfloor...Here some pics - post #91
allure trafficMASTER
I installed the flooring over a year ago, and have been very happy with the results...
Side note: in one of the pic's you can see our original plaid gaucho...I didn't lay the flooring beneath the gaucho...so a couple of months ago, we decided to rip out the old, dated gaucho and replace it with a futon from Ikea (Ikea has several mattress upgrades and several colors of slip covers - neat!)
I cleaned up the now exposed subfloor and went back to Lowes for another box of Prego...only to find they don't sell this pattern any more!!...kind of nicked me off, as they had this pattern as part of their ongoing displays...anyway, after much effort with a couple of their flooring 'experts', I found in a catalog a pattern called plain 'Tigerwood', which looked real close, and they ordered me a box - I figured you can't see much of it anyway under the futon, and as long as it was close it would be OK...well after a week or so it comes in and the pattern is identical with ours, even though they've dropped the 'Indian' part of the name...go figure...
We went with a dark blue slip cover for the futon, as our AS is named 'Blue Halo'...I had an auto upholstery make me up some wall cover pads, similar to the old plaid panels behind the gaucho, and for the wall paneling next to each of the twin beds...looks good with the Tigerwood Prego flooring, as well...
Here's some pics after changing the gaucho...color is kind of washed out in these pics taken on a bright day...the panel by the twin bed is a better color match...
Tore out the Gaucho today...
The cat is also happy with the new gaucho....
Let us not be too particular; it is better to have old secondhand Airstreams than none at all.
Mark Twain, updated (org...diamonds)
AIR # 11135
1978 - 28 ft Ambassador (Blue Halo)
2001 - Ford Excursion V-10 4x4
Which Flooring???? AndyPenny Floor Finishes 29 09-18-2008 03:26 PM
Flooring arjo Repairing/Replacing Floor &/or Frame 19 04-28-2008 05:57 AM
Bamboo floors M&J Siegford Floor Finishes 27 07-04-2005 06:29 AM
Bamboo floor replacing carpet Pahaska Floor Finishes 28 05-30-2005 09:48 PM
Flooring Fun-Lovin Floor Finishes 8 09-09-2003 11:15 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Mustang Forums - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - RV Forum - Truck Conversion - U2 Music Forum - Campground Reviews - Forest River - Sunline Trailers - Fiat Forum - Retirement Calculator
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© copyright 2002-2010 Social Knowledge, LLC All Rights Reserved.
